Re: FreeEMS-Loader
Posted: Wed Dec 08, 2010 3:44 am
Pushed a change to the .gitignore!
Connect button still behaves weirdly. No other testing done.
fred@roadeee [19:30:57]:src$ qmake
RCC: Warning: No resources in 'resource-root.qrc'.
fred@roadeee [19:31:05]:src$ make
Makefile:201: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:195: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:207: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:201: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:213: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:207: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:233: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:230: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:236: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:233: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:239: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:236: warning: ignoring old commands for target `ui_freeems_loader.h'
FreeEMS_LoaderComms.cpp: In member function ‘void FreeEMS_LoaderComms::read(char*, size_t)’:
FreeEMS_LoaderComms.cpp:135: warning: enumeration value ‘resultInProgress’ not handled in switch
FreeEMS_LoaderComms.cpp: In member function ‘std::string FreeEMS_LoaderComms::readStringUntil(const std::string&)’:
FreeEMS_LoaderComms.cpp:186: warning: enumeration value ‘resultInProgress’ not handled in switch
freeems_loader.cpp: In member function ‘void FreeEMS_Loader::redirectCLI()’:
freeems_loader.cpp:57: warning: unused variable ‘coutRedirector’
FreeEMS_LoaderComms.h:15:29: error: boost/utility.hpp: No such file or directory
FreeEMS_LoaderComms.h:16:26: error: boost/asio.hpp: No such file or directory
FreeEMS_LoaderComms.cpp:13:26: error: boost/bind.hpp: No such file or directory
fred@roadeee [18:36:02]:src$ make
Makefile:203: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:197: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:209: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:203: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:215: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:209: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:235: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:232: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:238: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:235: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:241: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:238: warning: ignoring old commands for target `ui_freeems_loader.h'
g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_XMLPATTERNS_LIB -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtXmlPatterns -I/usr/include/qt4 -I/usr/X11R6/include -I. -I. -o FreeEMS_LoaderParsing.o FreeEMS_LoaderParsing.cpp
In file included from FreeEMS_LoaderParsing.cpp:9:
freeems_loader_types.h:38: error: function definition does not declare parameters
freeems_loader_types.h:48: error: function definition does not declare parameters
make: *** [FreeEMS_LoaderParsing.o] Error 1
freeems_loader.cpp:65: error: cast from ‘StdRedirector<char, std::char_traits<char> >*’ to ‘int’ loses precision
cc1plus: warnings being treated as errors
/opt/local/include/boost/system/error_code.hpp: At global scope:
/opt/local/include/boost/system/error_code.hpp:214: warning: ‘boost::system::posix_category’ defined but not used
/opt/local/include/boost/system/error_code.hpp:215: warning: ‘boost::system::errno_ecat’ defined but not used
/opt/local/include/boost/system/error_code.hpp:216: warning: ‘boost::system::native_ecat’ defined but not used
/opt/local/include/boost/asio/error.hpp:251: warning: ‘boost::asio::error::system_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:253: warning: ‘boost::asio::error::netdb_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:255: warning: ‘boost::asio::error::addrinfo_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:257: warning: ‘boost::asio::error::misc_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:259: warning: ‘boost::asio::error::ssl_category’ defined but not used
make: *** [freeems_loader.o] Error 1
