View unanswered posts | View active topics It is currently Mon Jan 18, 2021 10:39 am
Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 10  Next
FreeEMS-Loader
Pushed a change to the .gitignore!
Connect button still behaves weirdly. No other testing done.
Wed Dec 08, 2010 3:44 am
You never pulled in my last commit, so I rebased it on top of your latest two. Please pull it in before proceeding :-)
Just built on deb sid and got these messages building:
Code:
fred@roadeee [19:30:57]:src$ qmake
RCC: Warning: No resources in 'resource-root.qrc'.
fred@roadeee [19:31:05]:src$ make
Makefile:201: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:195: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:207: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:201: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:213: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:207: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:233: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:230: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:236: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:233: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:239: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:236: warning: ignoring old commands for target `ui_freeems_loader.h'
Code:
FreeEMS_LoaderComms.cpp: In member function ‘void FreeEMS_LoaderComms::read(char*, size_t)’:
FreeEMS_LoaderComms.cpp:135: warning: enumeration value ‘resultInProgress’ not handled in switch
FreeEMS_LoaderComms.cpp: In member function ‘std::string FreeEMS_LoaderComms::readStringUntil(const std::string&)’:
FreeEMS_LoaderComms.cpp:186: warning: enumeration value ‘resultInProgress’ not handled in switch
freeems_loader.cpp: In member function ‘void FreeEMS_Loader::redirectCLI()’:
freeems_loader.cpp:57: warning: unused variable ‘coutRedirector’
And when pressing "connect" it changes to disconnect, but just says "qt slot fired" and doesn't seem to talk to the device. If you hit disconnect it doesn't change back to connect and just outputs qt slot fired again.
I'll try to build on win and mac now and post again when I've got more to say.
Fri Dec 10, 2010 7:40 am
Code:
FreeEMS_LoaderComms.h:15:29: error: boost/utility.hpp: No such file or directory
FreeEMS_LoaderComms.h:16:26: error: boost/asio.hpp: No such file or directory
FreeEMS_LoaderComms.cpp:13:26: error: boost/bind.hpp: No such file or directory
Got that on mac, assume it has something to do with your lib path settings in the .pro? Or maybe my environmental setup? I'm not sure, no more time to work on this today, posting from mac now.
Sat Dec 11, 2010 1:58 am
It wont build for me anymore:
Code:
fred@roadeee [18:36:02]:src$ make
Makefile:203: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:197: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:209: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:203: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:215: warning: overriding commands for target `moc_freeems_loader.cpp'
Makefile:209: warning: ignoring old commands for target `moc_freeems_loader.cpp'
Makefile:235: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:232: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:238: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:235: warning: ignoring old commands for target `ui_freeems_loader.h'
Makefile:241: warning: overriding commands for target `ui_freeems_loader.h'
Makefile:238: warning: ignoring old commands for target `ui_freeems_loader.h'
g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_XMLPATTERNS_LIB -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtXmlPatterns -I/usr/include/qt4 -I/usr/X11R6/include -I. -I. -o FreeEMS_LoaderParsing.o FreeEMS_LoaderParsing.cpp
In file included from FreeEMS_LoaderParsing.cpp:9:
freeems_loader_types.h:38: error: function definition does not declare parameters
freeems_loader_types.h:48: error: function definition does not declare parameters
make: *** [FreeEMS_LoaderParsing.o] Error 1
Fri Dec 24, 2010 6:38 am
hmmmm...... builds on my system.
try
make clean
qmake
make all
You snooze, you lose!
Fri Dec 24, 2010 7:27 pm
Profile YIM
maybe now would be a good time to address this warning :)
freeems_loader_types.h:38: warning: extended initializer lists only available with -std=c++0x or -std=gnu++0x
freeems_loader_types.h:46: warning: deprecated conversion from string constant to ‘char*’
Fri Dec 24, 2010 7:39 pm
Profile YIM
-Wall -Werror are your friends :-)
I know that it's weird, of course I cleaned etc. I have no idea why it's broken... I'll try again on your next push / my next pull. Otherwise maybe a g++ upgrade.
Fri Dec 24, 2010 11:14 pm
Sean, I finally got the macports stuff built just a few minutes ago. Now all three of my build environments produce the same errors on those lines. Totally seperate and different environments! The ONLY common factor is ME :-) But they are all broken. I'm filing a bug report, damn it! :-)
Wait, I didn't see this before!!! :
That's the answer! Clearly you need to reformat those initialisers so that they're not of that newer type for my 3 older compilers, and they are all fairly recent, too, at that.
Mon Dec 27, 2010 2:44 pm
Latest from the mighty mac, this is on macports, haven't tried fink yet, and seemed to need unix:INCLUDEPATH += /opt/local/include in the .pro file to make it work, but that could be my setup issues. In any case, it's back to a code issue again now, which means we're close to having it work on a mac:
Code:
freeems_loader.cpp:65: error: cast from ‘StdRedirector<char, std::char_traits<char> >*’ to ‘int’ loses precision
cc1plus: warnings being treated as errors
/opt/local/include/boost/system/error_code.hpp: At global scope:
/opt/local/include/boost/system/error_code.hpp:214: warning: ‘boost::system::posix_category’ defined but not used
/opt/local/include/boost/system/error_code.hpp:215: warning: ‘boost::system::errno_ecat’ defined but not used
/opt/local/include/boost/system/error_code.hpp:216: warning: ‘boost::system::native_ecat’ defined but not used
/opt/local/include/boost/asio/error.hpp:251: warning: ‘boost::asio::error::system_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:253: warning: ‘boost::asio::error::netdb_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:255: warning: ‘boost::asio::error::addrinfo_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:257: warning: ‘boost::asio::error::misc_category’ defined but not used
/opt/local/include/boost/asio/error.hpp:259: warning: ‘boost::asio::error::ssl_category’ defined but not used
make: *** [freeems_loader.o] Error 1
EEE works, though! :-)
Tue Dec 28, 2010 11:46 pm
All fixed, congrats, Sean! Mac users will be happy to note that it builds just fine on the Mac using Macports. It may work with fink too, but that remains to be seen. I built it using the mac version of QT not the X11 version. The other should work the same. Anything else, I don't know about, but here is a screen shot:
http://stuff.fredcooke.com/FreeEMS.Load ... cports.png
Wed Dec 29, 2010 6:17 am
