No, they are not. What if I have an ignitor that needs to be driven HIGH to dwell? Your solution fails. If it's just the on board IGBTs then there is no reason to worry about what you are worrying about, I would rather buy a BDM and offer a service to fix bad bootloaders IF they ever change...ababkin wrote:If this works, the user is relieved from having anything to do with polarity - no jumpers, no check boxes, no fried coils and flooded engines, no figuring needed polarity out - it just works. You've formulated the problem, i've proposed a solution.
