View unanswered posts | View active topics It is currently Mon Jan 18, 2021 4:29 am
Reply to topic  [ 2 posts ]
A bit of information please. FeeMS2 test
Hi to all, i want test the FreeMS2 (https://github.com/fredcooke/FreeMS2) from on a MS2 (PCBv3.0) ecu.
I burn the bootloader (FreeMS2-SerialMonitor-1.0.s19) with USBDM. https://github.com/fredcooke/FreeMS2/bl ... or-1.0.s19
But now, how can i load the firmware? i no found Loader installer, (windows) (http://powerefi.com/files/FreeEMS-Loade ... er-RC7.exe)
If i use my USBDM ot hcs12mem with TBDML, the ecu not response.??????????????????
I am try connect it with "EMStudioInstaller.i386.DEV.2014-05-08_21-38-50"
I do not want to have to compile the loader. https://github.com/seank/freeems-loader :oops:
Nobody can share the loader installer, please? :?
I was looking the code, can MS2 processor use 6 injector ports really? :o :o :o
Thu Oct 27, 2016 11:12 am
I've got some bad news for you! FreeMS2 is a VERY old version of FreeEMS ported to MS2 hardware, however it has NO comms implemented as you can't use the same strategy on MS2 due to a lack of RAM. Equally it requires a paged tuning model, which we do not do yet. It's not written into FreeMS2, either. I basically got the base running and gave up as it's not worth the trouble. Throw MS2 in the bin, be happy :-)
Thu Oct 27, 2016 11:18 am
