0) Car setup hate list
- 26/05/14 IAT heat soaks and is a slow moving plastic one, results in lean running sometimes
- 26/05/14 Injectors aren't consistent and result in lean running sometimes
- 26/05/14 Lack of cold idle valve of any type
- 26/05/14 Lack of keyboard backlight + weight of laptop + more, but it was free, can't complain.
1) Firmware hate list
- 26/05/14 Lack of proper support for coil-follows-input style dwell
- 26/05/14 Lack of sensor fail over protection
- 26/05/14 Lack of tip in enrichment
- 26/05/14 Lack of proper warm up enrichment algorithm 09/04/15 Note, this only affects fuel economy, really. On steep WOT sections it may bog too. No longer have steep sections in commute.
- 26/05/14 Lack of proper starting fueling setup
- 09/04/15 Lack of after-start enrichment
- 09/04/15 Lack of better timed priming function
2) Build hate list
- 26/05/14 Having to build EMSTune from the top dir and run it from core, VERY error prone...
- 26/05/14 Not having proper versioned apps with my own closed source junk
3) Log viewing hate list
- 26/05/14 Having to manually range-adjust my log traces
- 26/05/14 Having to select the same shit every time in my log viewer
- 26/05/14 Not being able to batch-open logs
- 26/05/14 Lack of proper view/parse arch
- 26/05/14 Various things that OLV has that ULV does not
4) Tuning hate list
- 27/05/14 Bad default window sizing and lack of scaling, only scrolling, font size huge, etc
- 27/05/14 Inability to group, order and manipulate numeric values which are naturally in an annoying order from the fw
- 27/05/14 No "dark mode" for night tuning, which is the bulk of tuning, all backgrounds dark grey or black, darker mix of colours for tables, etc.
- 26/05/14 Having to kill EMSTune to get a new log file with metadata in it. EDIT: Seconded! http://issues.freeems.org/view.php?id=934
- 26/05/14 Not being able to choose a log file name once the above is sorted
- 26/05/14 Gauges all read wrong, and update too slowly
- 26/05/14 Having to close 2d tables to see the curve updated, EMSTune again
- 26/05/14 No tracing in 3d tables, 2d tracing very very wrong
- 26/05/14 Tunable list popping up over what you're doing after a dialogue!!! :-/
- 26/05/14 Lack of offline mode in EMSTune, really annoying having to work on the car for offline adjustments
- 26/05/14 Lack of nice disconnect/connect display, but he's changed this, not tried it yet! Tried it, still not good enough.
5) Firmware load hate list
- 26/05/14 Not being able to say "put the latest on the car"
