View unanswered posts | View active topics It is currently Fri Mar 22, 2019 5:07 pm
Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Freeems Toolset ArchLinux (un)Official Support
So, I am packaging the tools necessary to work with freeems (with the expection of the firmware itself)
    Principles:
  • The software will be build directly from the git repositories, from devs to devs
  • The tools shall no interfere with any existent non freeems related tools.
  • Be installed with a single command eg. packer -S freeems-toolset
    What's packaged:
  • freescale-s12x-binutils-xgate-git
  • freescale-s12x-binutils-m68hc11-git
  • freeems-serialio-git
  • freeems-loader-git, still on the works with 0000839 and 0000840
  • emstudio-git, also, worked around. 0000841
    What's not packaged yet:
  • freescale-s12x-gcc-git, on the works 0000842
  • freescale-s12x-newlib-git
    Less relevant TODOs:
  • Give Icons and desktop entries to emstudio and the loader
  • Create a freeems-toolset metapackage
  • Upload it All to the AUR
  • Create a daily built repository
I keep all the packages at
https://github.com/masterkorp/pkgbuilds ... ms-toolset
I will keep you guys updated.
Wed May 08, 2013 1:47 am
Good stuff, masterkorp! :-)
Wed May 08, 2013 1:50 am
I am having trouble with gcc, reported 0000842
Wed May 08, 2013 2:06 am
Good news, FreeEMS Loader compiles and starts just by disabling -Werror flag, That's a start. I plan to test a firmware load soon.
Thu May 09, 2013 2:28 am
The same works with emstudio, disabling -Werror. It builds and starts.
Altough that missing json error is still present.
Thu May 09, 2013 10:53 am
EMStudio, FreeEMS-SerialIO and FreeEMS-Loader are on the Archlinux User Repository.
So all you need to do to get them is to use your favorite AUR warpper like so:
Code:
packer -S emstudio-git freeems-loader-git
And they shall be built and installed for you.
Also, to update you just rebuild them. Like so.
Code:
packer -Syu --devel
This will rebuild all -git packages and update your system, its common practise to do so to keep uptodate.
If you want to just upgrate emstudio and or freeems-loader-git just use the same command you used to install it.
Thu May 09, 2013 11:26 am
Up list updated, I might put my skills to use and later build a proper CI server and a start with an ArchLinux repository.
Thu May 09, 2013 11:35 am
I don't use Arch, but I commend your actions! Badger Sean and Mike about their non-strict compiler issues :-)
Thu May 09, 2013 12:56 pm
As an Arch user I approve of this thread.
Thanks for your hard work masterkorp :-)
Thu Jun 06, 2013 7:05 am
Which package(s)?
-sean
You snooze, you lose!
Sun Jun 23, 2013 6:04 pm
Profile YIM
