Page 1 of 1
Issue Tracker Privileges Revoked
Posted: Sat Dec 29, 2012 12:58 am
I just removed everyone back to reporter for blanket privileges. Clearly you'll not be able to do what you need to anymore, so whinge to me when that's a problem and I'll give you fine-grained permission to do what you need to. This is necessary due to a limitation in the UI of mantis. Apologies for the inconvenience.
Whinge here if you like, or via IRC/email/whatever.
Re: Issue Tracker Privileges Revoked
Posted: Thu Jan 03, 2013 6:05 pm
by BenFenner
I assume I'll need some permissions back.
Posted: Thu Jan 03, 2013 6:26 pm
Assume nothing, it wastes my time, check it. Some people were setup correctly before.
Posted: Wed Jan 09, 2013 10:41 pm
by BenFenner
Checked, and all seems good. Will let you know if that is not the case once I start using it again in earnest soon.
Posted: Wed Jan 09, 2013 11:03 pm
Just added you to EMStudio as updater after request from Mike, too. Lemme know what else :-)
Posted: Fri Jan 11, 2013 2:29 pm
by Dan
if not logged in, one cannot see any issues on the tracker at all
Posted: Fri Jan 11, 2013 2:36 pm
by Dan
even when logged in, I can only see issues I have raised. I can't see any other issues at all from any section/project.
EDIT: added snapshot
Posted: Fri Jan 11, 2013 11:32 pm
Total fail. Should be fixed now. Please confirm it operates as you expect. Thanks for reporting these issues issues.
Posted: Sun Jan 13, 2013 1:04 pm
by Dan
fixed, in both cases! All Good now!
Posted: Sun Jan 13, 2013 2:05 pm
Thanks mate! Appreciate your efforts! :-)
