getting started
JareeB
getting started
im not sure how to really start with freeems. i saw in the update thread that you use Adapt9S12XDP512M2 XGATE MCU Module, and im not sure what you do once you buy that. plan is to start with a small engine and work up to my ford ranger.
plans to build a 300whp turbo ford ranger with a 2.3l engine the ford lima!
current rig: 1994 ford ranger 2.3. good platform for my almost complete turbo engine. a237 cam, stock t3 turbo, ported and polished head. just needs some mangement!!
Re: getting started
I'd probably recommend not buying a CPU module and waiting for a full board solution from Andy or Dan or someone. Most people who buy CPU modules don't ever get them onto a car. Most people who get real boards do. Fact of life :-)
JareeB
Re: getting started
thanks for the fast approval. im really excited about finding this website/forum. is there any schematics around that work? that i could have made into a pcb? also how close is the programming language to arduino?
JareeB
Re: getting started
i found the pcb file for jaguar and the files on how to put it together. how would i get it made into a pcb?
Re: getting started
Yep, Fred is correct. DeuceEFI here on the forums (Andy) has developed hardware called Jaguar which is excellent and is continually improving. I am also very close to releasing hardware called RavAGE as well. Both designs are very good and are subject to strict development guidelines. What are your current injector, ignitor requirements and crank/cam sensor specs? Welcome to the forums!
Re: getting started
Tame the excitement, read this: viewtopic.php?f=41&t=1699 and get a partial unit from Andy in, hopefully, less than a month or so. This represents a saving on special tools and equipment required to assemble one from the ground up, and supports Andy who deserves some support :-) Win Win Win.JareeB wrote:i found the pcb file for jaguar and the files on how to put it together. how would i get it made into a pcb?
JareeB
Re: getting started
@dan, i could run high or low inpulse injectors doesn't matter to me i can get either one. for ingnitor i would just run ls coils to keep it simple. crank/cam sensor i belive the ford 2.3 with edis has the 36-1 gear on the crank, ill look into that, but obd2 rangers with 2.3 engine have both a crank and a cam sensor, the cam sensor is on the valve cover so i could just swap the cover onto my obd1 engine.
@fred, sorry haha its that time of year i guess.
Re: getting started
Get some modern high-z injectors and save yourself a lot of unnecessary pain ;-)
JareeB
Re: getting started
alright. where would i find on here the update threads for the RavAGE. i couldnt seem to find that one on here.
edit: found it on my own.
viewtopic.php?f=9&t=1217
