View unanswered posts | View active topics It is currently Mon Jan 21, 2019 10:53 pm
Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
hello
MotoFab wrote:
Output pins from processors also typically only drive 20mA, and must be connected to a driver transistor to make a PWM signal that can drive something practical.
In the same way, usual practice puts a current buffer transistor after the high impedance DAC output pin to serve as the DAC driver. Which is identical to the usual practice putting a current buffer transistor after the processor output pin to serve as a the PWM driver.
I don't know why we're still talking about dacs. Are you saying you want to use a micro-controller that has PWM capability to drive a dac that uses PWM to drive a transistor? <- rhetorical question in case you were wondering
It seems like part of this circuit is redundant, but I can't figure out which part.
Hip Hip Hooray for turning this thread into a pointless argument. lmao
:-p
Wed Mar 07, 2012 9:28 pm
I didn't think we were talking about DACs. Fred paints himself into a corner and then reacts. Nothing new here. Many of us more capable resources hope he grows out of it. It's a big hindrance to contribution. Honest and truly.
Wed Mar 07, 2012 9:50 pm
You can trust Jim to fuck up, well, anything, really. Peter, if you say the word, I can remove his entire account. I can't be fucked dealing with him anymore.
Jim, you'd have to contribute 100k USD before you were worth the trouble you've caused here. Quite frankly, you've never done more than stir shit, likely all you're good for.
Wed Mar 07, 2012 9:56 pm
I remember once upon a time 'stirring shit' as you call it regarding transient fueling. And here you are 2 years later incorporating it into the code. There are more examples. Overall though, good thing you eventually deal with whatever gets stirred up. I'm thinking the learning process could go a lot easier both for you and the resources, and I hope it does. This project has a lot of potential.
Wed Mar 07, 2012 10:28 pm
God damn you Fred for hindering contribution to this project, look at transient fueling that "feature" could have done two years ago when there were 800 more important problems. lol I don't even know how you could come to that conclusion. Fred's the only reason this project is a viable option for an engine management system. Just out of curiosity Motofab, what have you contributed to this project? On second thought never mind, one I don't care and two this isn't the place to be discussing such things.
I'll leave that up to you. I find him rather entertaining, other than the fact that this isn't the place for it.
Fred wrote:
100k USD
Damn! That's an expensive FreeEMS license, or maybe that's a user support/developer patience fee.
Hum, it probably has something to do with your attitude. Like right now with the "I told you so!" Look at me "my" idea was right, but I didn't help develop the feature, that's for the underlings, I'm an idea man. roflmao
NinjaRider: Sorry for making a complete mess out of your thread.
And because I like comics.
:-p
Wed Mar 07, 2012 10:53 pm
What's worse, Peter, is that I'm NOT adding that to the code, and have no immediate plans to, what so ever. I'm not even adding normal accelerator pump action to it. Jim is just full of subtle insults and undermining behaviour, as always. Thanks for your support, Peter!
Wed Mar 07, 2012 11:03 pm
wow. i work for a couple hours to find a off the course thread.
@Peter and all. im not talking about using a DAC to control the IAC. That would be completely pointless. the iac should probably stay the way it is.
the vacuum bypass that i was refering to by the zx600k1. by each throttle body there is a small drilled relief that allows air to bypass the throttle plate. the whole is opened and closed with tapered needle screw by which you calibrate vac for the cyl for 20vac. allowing you to program the computer knowing exactly how much air is bypassing the throttle plate at given rpm. another way to do it would be to convert to a maf which would require a lot of replumbing.
Wed Mar 07, 2012 11:24 pm
What exactly ARE you talking about driving with a DAC then? Unless it's a pair of head phones, you're probably off course as much as the thread is.
Wed Mar 07, 2012 11:30 pm
dont know if i would need a vol dac or an cur dac, but i want to drive special designed solenoids to actuate the valve train and remove the cams and all associated timing components.
Wed Mar 07, 2012 11:43 pm
