Log File Context Form Template
Posted: Mon Oct 03, 2011 9:59 pm
Guys, motivated by Preston and his mostly awesome log file names and associated emails, I thought it would be good to include in the firmware docs dir a simple form with fields to fill out before uploading, sending, attaching, reporting anything involving a log. A log without context is somewhat useless. I'll start the ball rolling and when the thread has got far enough along I'll put it into a file and commit it.
Notes:
- Version: Firmware release version X.Y.Z or development git hash (git describe)
- Decoder: Name of the decoder, file name uploaded and/or name pulled out of the firmware through MTX or other tools
- Modifications: If building from source, ALWAYS a git status paste and, if that's not clean, also git diff paste.
- Custom logging: A listing of the ./src/custom directory, and if datalogPopulator.c is present, the contents of that file.
- Description of mods: What your changes are supposed to do.
- Type(s) of log file(s): standard binary, megatunix csv, logic analyser/scope mode (what it was pointing at).
- Weather conditions: Hot/cold, night/day, stop start traffic, humid ocean air, dry desert air, etc.
- Summary of behaviour: What you observed, concisely.
- Detailed description of behaviour: Everything you noticed about what you observed.
- Where in the log file is the evidence: Time stamp, log record number, which fields, shapes to look for, range values to set, etc.
- Vehicle info: Chassis/body and engine type and variant, mods, power adders, sensor types, etc.
- Hardware: Type of hardware, circuit configurations, etc. eg "Puma Spin 1 with recommended hacks" or "TA + ravage based circuits" etc.
- Recent changes to hardware: Where hardware = engine, loom, sensors, circuits, etc, anything you can solder or unbolt :-)
- Relevant settings: Anything that you've recently changed about your setup, or changed since last specifying it publicly, or if it's a fresh setup, everything.
- Description of driving style/actions: cranking/starting, idling, free revving, soft driving, race track use, traffic light racing, drag racing, burnouts, etc.
Notes:
- Fill out everything you can, if you can't, say so:
- Stuff you don't know should say "Don't know"
- Stuff that isn't applicable should have "N/A"
- Stuff that is same as before should say "same"
- If we don't know your essentials then we can't support you.
- If you're running unofficial/forked/customised code from a repo that isn't mine, expect less support.
- Where possible rip your firmware, as-is, zip and include it so it can be verified on the bench if required.
