Total good lines: 3689
Found and ignored non-S2 record! Type: S0
Found and ignored non-S2 record! Type: S8
Total contiguous blocks: 16
Opening serial device: /dev/ttyUSB0
Opened serial monitor comms!
Successful dinfo: 6 {0xDC, 0xC4, 0x10, 0xE0, 0x00, 0x3E, }
PPAGE: 0xE0 Start address: 0x8800 Size: 484 Writes: 2 of which 1 are full size.
.. DONE!
PPAGE: 0xE1 Start address: 0x8000 Size: 144 Writes: 1 of which 0 are full size.
. DONE!
PPAGE: 0xF8 Start address: 0x8000 Size: 258 Writes: 2 of which 1 are full size.
.. DONE!
PPAGE: 0xF9 Start address: 0x8000 Size: 767 Writes: 3 of which 2 are full size.
... DONE!
PPAGE: 0xF9 Start address: 0xA000 Size: 8192 Writes: 32 of which 32 are full size.
................................ DONE!
PPAGE: 0xFA Start address: 0x8000 Size: 275 Writes: 2 of which 1 are full size.
.. DONE!
PPAGE: 0xFA Start address: 0xA000 Size: 8192 Writes: 32 of which 32 are full size.
PPAGE: 0xFB Start address: 0x8000 Size: 303 Writes: 2 of which 1 are full size.
.. DONE!
PPAGE: 0xFB Start address: 0xA000 Size: 8192 Writes: 32 of which 32 are full size.
PPAGE: 0xFC Start address: 0x8000 Size: 275 Writes: 2 of which 1 are full size.
.. DONE!
PPAGE: 0xFC Start address: 0xA000 Size: 8192 Writes: 32 of which 32 are full size.
PPAGE: 0xFD Start address: 0x8000 Size: 5543 Writes: 22 of which 21 are full size.
PPAGE: 0xFD Start address: 0xB800 Size: 2048 Writes: 8 of which 8 are full size.
........ DONE!
PPAGE: 0xFE Start address: 0x8000 Size: 5441 Writes: 22 of which 21 are full size.
PPAGE: 0xFF Start address: 0x8000 Size: 10350 Writes: 41 of which 40 are full size.
......................................... DONE!
PPAGE: 0xFF Start address: 0xB710 Size: 240 Writes: 1 of which 0 are full size.
. DONE!
Total writes: 236
Full blocks: 225
Total bytes: 58896Code: Select all
real	0m22.916s
user	0m3.228s
sys	0m0.512sCode: Select all
real	1m6.874s
user	0m7.844s
sys	0m1.668sBed :-)
