Where to Start.....
disneyjoe7
Re: Where to Start.....
Post by disneyjoe7 »
disneyjoe7
Well I'm new this DYI EFI, but I know engines as tuned them to run great since I was a kid. I have build a Microcontroller device to control C-Band dish, around a PIC16f877a with ASM. And I work as a Electronic Tech for a phone company. I look forward to play with this DYI-EFI.
Thinking a normal system that would control 3 spark coils, 6 injectors, 2 O2, and 1 Wide O2 sensor. When working with HHO it would maybe with only the wide 02 senser, and not the 02 sensors. This engine is a V6 3.4L with 3 spark coils.
disneyjoe7 wrote:DIYEFI Runs on this right?
http://www.technologicalarts.ca/catalog ... cts_id=367
DIYEFI.org runs on a Debian server, FreeEMS runs on the above board, among other things, yes :-)
disneyjoe7
Fred,
Can I post a video about HHO?
Steve
disneyjoe7
Sorry to confuse some people here.
In short what I wish to do is redo an ECU to an engine so it could be able to handle HHO fuel injection.
See this video.
http://youtu.be/jJS8JFIqhh4
disneyjoe7 wrote:Fred,
Steve
Strange question!!! You already did on the last post in the previous page, and, as I see, in the next post too! :-/
Don't feel the need to explain yourself for the sake of it :-)
oden
Post by oden »
My plan is to not wire the whole engine, but to get an ECU case so anything needed to do could be in the case, so the case / ECU could be installed and work or the original ECU could be re-installed so everything is stock again.
You will not be able to remove your OEM ECU and replace it with FreeEMS. There is alot of other 'stuff' that the OEM ECU does
disneyjoe7
Steve
I run another phpBB forum and I was able to post a video. A video that would show here, and not just a link. I'll check to see how I do it on my forum.
disneyjoe7
I know what you're saying but I think I can :idea: :geek: :ugeek:
disneyjoe7
Ok jumped in with both feet. I ordered the Adapt9S12XDP512M2, I play with it and I learn it. :smile:
