Page 4 of 6
Re: ULV Pictorial Development Diary
Posted: Sun May 05, 2013 12:04 am
Finally, ULV has been in real world use on my machine for some days working with real files for real reasons. Here's the original uncropped screen shot of the 4 cylinder engine using J Series decoder. Uploaded May 4th, yesterday!
Posted: Sun May 05, 2013 11:38 pm
Posted: Mon May 06, 2013 9:41 pm
To steal a term from Ben, I've been "dogfooding" all day, and it's been a great success! It's kinda crappy to use in some ways, and obviously unfinished in others, but by using it you get a real feel for what's most broken, and what to fix next. Here's a shot taken "just now" of a log loaded some hours ago while debugging a decoder change I was making:
Posted: Tue May 07, 2013 7:40 pm
The min/max display was annoying me a bit, so I added a quick control for it! Finally, at last, the "control panel" is actually a control panel, at least, a little bit :-) Taken "just now":
Posted: Wed May 08, 2013 11:22 am
I decided to do something easy this morning, after only 4 hours sleep... so I added fill mode to the min/max rendering. It makes this log of Sim's RPM vs Battery Voltage pretty obvious. At lower RPM there is a lot less noise. Uploaded "just now":
Posted: Wed May 08, 2013 11:50 am
Now controllable, and with distinct edge and fill colours:
Re: ULV Pictorial Development Diary (56k die)
Posted: Wed May 22, 2013 8:03 pm
Posted: Wed May 22, 2013 9:24 pm
Simple histograms are now real, except it's always RPM, if available, or the first record if not. Colour is cycled from a list. Obviously needs bin range labels and scale and counts and title and so forth. But if you know what it is, then the shape is all that really matters.
Edit: The title was hard coded in the previous "implementation", now corrected to be real.
Edit2: My theories on what you're looking at:
the highest bar is idle
the other bump that is half bell-curve is likely "cruise"
the flat bit "between idle and cruise" and the taper off "enthusiasm"
that bump below idle is the "nearly stall" bit, I think
i think this log started while idling
could be wrong
if wrong, the first bit includes cranking, AND the near stalls
no way could the first bin be that big without the near stalls IMO
Posted: Thu May 23, 2013 2:40 pm
A few subtle enhancements to it, ie, wider bars, configurable background, 50 bins instead of 20, reasonable min size, etc.
Posted: Sat Jun 08, 2013 1:03 am
Had to lose a 2 week ulv-uptime. Running the same version for all of my log viewing needs for 2 whole weeks. Killed it so I could change a few things. Fixed a little bug in the window menu stuff, unnoticed by anyone else, annoying to me. Histogram now has selectable field and bin count:
