View unanswered posts | View active topics It is currently Thu Apr 09, 2020 12:20 pm
This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page Previous  1, 2, 3
The Ultimate Loader
I've broadened my functional test suite for the app and libs and discovered a few weaknesses that could make it more generally useful if fixed. It's relatively minor to fix them, and recognising them is required for reliable handling of the various different formats anyway, even if I don't support some. I've also uncovered a few new tricks which is at the least interesting, and at best very useful. More to come :-)
Mon Nov 19, 2012 1:01 am
A bit less ugly than before:
Code:
fred@cheetah:~/workspaces/eclipse/serial-monitor$ java -jar demoUL.jar
Welcome to the UltimateLoader experience!
Got 0 arguments with wrong structure! Usage:
About this version: java -jar demoUL.jar about
Check firmware:     java -jar demoUL.jar <firmware.s19>
Load firmware:      java -jar demoUL.jar <firmware.s19> <serial device>
Fast load firmware: java -jar demoUL.jar <firmware.s19> <serial device> noverify
Rip device to file: java -jar demoUL.jar <serial device>
Erase device only:  java -jar demoUL.jar <serial device> erase only
Note: Valid S19 file extensions: {s19, s28, s37, s1, s2, s3, sre, srec, mot, abs}
Note: S19 file arguments may also be supplied gzipped with extra .gz suffix
Note: Serial devices are in the form COM1 on Windows and /dev/ttyUSB0 on Linux
Thank you for supporting FreeEMS!
Planning to totally overhaul the CLI stuff, as it's a bit patchy right now, though that can wait till after more robustness and features are added.
Tue Nov 20, 2012 9:43 pm
FYI, this app, and all others that I make will require a Java6 JRE, or newer. I played around with 1.5 bins tonight, but it would require too much change to not use some J6 features. Thanks to my secret tester for trying it on an old Mac. I can't even get J5 for Debian now anyway... so it's pretty obsolete, especially with J8 on the Horizon.
Thu Nov 22, 2012 9:43 pm
The UltimateLoader is now tested on OS X! It worked with both cu. and tty. versions too!
Sat Dec 01, 2012 4:28 pm
Fred wrote:
Expect some unique and desirable features to be present in it.
One of these is now present and functioning nicely. :-)
Sun Dec 16, 2012 7:12 pm
I wish I knew what the last post was about! Anyone who knows is welcome to PM me and explain :-D
Anyway, this is now packaged in a .deb for more convenient use. And I gave it a little tweak, too.
More to come, stay tuned! :-)
Tue Jun 28, 2016 12:28 pm
