View unanswered posts | View active topics It is currently Sun Jan 20, 2019 11:54 pm
Reply to topic  [ 88 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
my simple ECU
Now with EGT sensor
https://www.youtube.com/watch?v=nOi3Y5_x7BQ
http://forum.diyefi.org/viewtopic.php?t=2070 http://www.rusefi.com
Sun Sep 21, 2014 5:12 pm
Might be a good idea to have your gauge's indicate error's more clearly, but otherwise a nice little addition.
Is there anything the ECU can do with EGT, or is it more for logging/tuning purposes?
And finally: Did that thermocouple survive it's baptism of fire? It didn't look to great there at the end of the vid.
FABRICA MI DIEM, PVNC!
Sun Sep 21, 2014 5:35 pm
Actually up to eight gauges - but yes, just a gauge for now, but I am open to your ideas :) What kind of logic could be possible on top of EGT value?
If only other fancy inputs were same trivial as this one! MAX31855 does _everything_ here - all you do is consume 4 bytes via SPI, that's it.
It actually could be that the fire is the reason of the "open circuit" error - the wires were simply twisted together and the baptism by fire might have separated/contaminated them enough. I will re-shoot the video once I get some uber-cheap probes from China.
Sun Sep 21, 2014 5:45 pm
I suppose you could get a lot of carbon buildup sticking bare wire in open flames like that.
You could have an error indication somewhere inside the gauge I suppose, although not every sensor input will have error reporting capabilities off course.
I will be using the MAX31855 for my reflow controller myself, it struck me as a potentially useful IC for exactly what you are doing with it (EGT), so I ordered a few along with my MAX9926's.
Turned out they are also the go-to IC for building reflow oven controllers.
Sun Sep 21, 2014 5:54 pm
Is that actual copper wire you use to connect the EGT sensor? It is not supposed to be like that..
Just order some cheap EGT sensors from ebay for like 4 of 8 bucks each.
Than you get a metal nozzle around it to protect it from flames.. a k-type sensor can handle 1200C but the wires itself can only handle ~200C or so.
AND you get the propper wire material which are made out of the same metals as the EGT sensor it self which is mandatory to get a correct reading.
(i've build myself an EGT interface with the same chip ;))
Mon Oct 27, 2014 10:25 am
http://www.ebay.nl/itm/1pcs-3M-Stainles ... 4188757455
or a more fancy one:
http://www.ebay.nl/itm/su-2M-Screw-100- ... 1c4533b763
Mon Oct 27, 2014 10:29 am
No.
The "sensor" is the spot where two different wires couple. If you use same wires, there is no coupling spot thus no sensor thus the decoding chip (which I would not call a sensor but I am not a native speaker) would report "short" condition.
What you see on the video is a purposely-made thermocouple wire. It's the coupling which is executed poorly :)
I've got some cheap eBay K-probes, just never got the time to try them :( Too many little things on the TODO list.
Mon Oct 27, 2014 11:47 am
Yeah it is not a real 'sensor', I agree =] The video isn't that clear so I thought I give a heads up just to be sure =]
Mon Oct 27, 2014 11:52 am
http://www.youtube.com/watch?v=PhIWAPaUnYM
automatic Honda with a blown HG was not serving me well, finally I have a functioning test mule. I hope to figure out better cold start this year and get some miles on this vehicle.
Mon Nov 03, 2014 1:44 am
First time starting a cold engine, big day for me!
https://www.youtube.com/watch?v=UqBzuZEqcEo
Still not exactly perfect, probably need some tweaking of the coefficient curves and probably needs a new feature of extra fuel for first 10 seconds of running.
Mon Nov 10, 2014 8:16 pm
Users browsing this forum: Google [Bot] and 1 guest
