Hi guys, I have not looked at the memory footprint of the FreeEMS code, but I came to an idea to try to
port the (fueling) part of the FreeEMS code to Bosch LH 2.4 Jetronic. Do you think it is possible?
Jetronic is limited by RAM 256 internal + 256 optional external bytes, but have a lot of ROM /code space,
runs 8051 derived processor and is simple enough.
The point of doing this is to have stock ECU+wiring with an open software running on it. What do you guys think?
Porting FreeEMS to existing OEM ECU
Re: Porting FreeEMS to existing OEM ECU
Possible, but a waste of time IMO. "The fueling part", as it currently stands, you could rewrite in a day. IE, the vast majority of the work will be the infrastructure of the Bosch ECU. That's incidentally where many of FreeEMS' strengths are, in the structure. It's virtually feature-less right now, but there is an excellent framework. The framework would mostly have to change on a different device, so: start from scratch if you want to do that. BIG job, not worth it, IMO.
Well, you are right probably, but I know the hardware, and once I get to know the software it should not be that
hard. Also a chance to learn the internals of FreeEMS. At some point in the future I am planning to convert my Volvo to FreeEMS, but I will have to investigate existing builds, build my own supporting hardware, gather/make some sensors and so on.
And the most important - get enough free time do it.
Last time I looked at this project was maybe 1.5-2 years ago, and now I am very happy to find this project not only survived but also made some impressive progress. I am pro open source, and this is the most important reason I will go for FreeEMS.
Anyway, I will let you know how it goes, if at all, and who knows - I might be able to bring something
Fair enough! :-)wxorx wrote:Well, you are right probably, but I know the hardware, and once I get to know the software it should not be that
Cool, I look forward to your arrival in the chart :-)wxorx wrote:At some point in the future I am planning to convert my Volvo to FreeEMS, but I will have to investigate existing builds, build my own supporting hardware, gather/make some sensors and so on.
Yes, it has, but at great cost to me, something I need to rectify in the short term. As for the timing, it was just over 2 years ago that this video of engine #2 was filmed and it's been solid progress ever since. Lots more just around the corner, too, if people step up as they've promised to.wxorx wrote:Last time I looked at this project was maybe 1.5-2 years ago, and now I am very happy to find this project not only survived but also made some impressive progress.
It'll always be open source! It serves no purpose to the world if it's not. Knowing what I know now, I will absolutely never use anything on any engine again that isn't OEM, FreeEMS, or, gasp, in a dire emergency, MS2. MS1 is a pile of shit, and MS3 is just like all of the other brands, fully closed, and thus not acceptable to me anymore.wxorx wrote:I am pro open source, and this is the most important reason I will go for FreeEMS.
Quite possibly :-)wxorx wrote:Anyway, I will let you know how it goes, if at all, and who knows - I might be able to bring something
This applies to your porting too, btw: viewtopic.php?f=41&t=1699
PS, I de-n00bed you.
