mpc5634 based board
Posted: Sat Sep 04, 2010 10:14 pm
a dead simple board based on the 144lqfp part.. you supply +5, and everything else is pinned out for you to connect your own drivers, etc ..
any interest ? I might have a diy etched board up and running by the end of the weekend. if it works out, I'll go off and have some boards professionally made up with connectors and such (in the spirit of the ta board).
if you need a dev platform, iSystem has a full blown ide (winIDEA) w/gcc 4 (and a simulator!) .. and I wrote a c# cmdline app to push data into flash over the serial port. if you want to use a nexus debugger, expect to shell out a lot of money.
beware - it was hard for me to get samples of this part .. it might be even harder for you. this is a bleeding edge pre-prod part.
http://www.freescale.com/webapp/sps/sit ... dG06C1427E
