View unanswered posts | View active topics It is currently Tue Nov 24, 2020 1:47 am
Reply to topic  [ 53 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Cheapish HiFi Bookshelf Speakers Limited Tools NO Aesthetics
Split off from the amp thread!
I ordered some drivers to make speakers to drive with this thing, today! Time to design a set of boxes, and pull my finger out re getting PCBs made!
Thanks to MrOnion for automating my life!
Thu Feb 14, 2013 12:23 am
Dude! Hahaha... You learn finnish on the way too. Did this to my friends uncle a while back (well looks like 13 yrs) who publishes hifi magazines. Funny how you find your early "work" is still online and even usable...
.. and reminds you how many fucking years you have been sitting on this damn machine. ;)
Thu Feb 14, 2013 12:35 am
Did this to! LOL! What, like a punishment? ;-)
Thu Feb 14, 2013 8:03 am
How much is that doooogy in the window, toot toot, I do hope that doooogy's for sale, toot toot.
Went to look at wood. MDF. 19mm 300mm 2440mm 8.27l internal volume.
If I were to be horribly and unforgivably stupid and ignorant I'd make it a cube. If I did that, the internal walls, assuming no stuffing, no bracing, no speaker back intrusion, etc, would be:
3√8.27 = 2.02225151688209 decimeters or 20.2225 centimeters or 202.225mm, which would be awfully difficult to achieve with 300mm wide MDF, even after subtracting 38mm + 4mm for thickness and sawcuts.
So given my lack of tools, it'll likely be 300mm ID one way, and 300 - 38 the other, minus 20mm square corner braces, gives us a cross section of:
(30 * 26.2) - (2x2x4) = 770 sq centimeters! DuckDuckGo fucking ROCKS! (mixed multiplication symbols and it still works!)
Converting that to square decimeters is 7.7 more math required:
<went to bed, got up again>
Volume of the bracing is ID of each dimension minus 4cm, times 2cm * 2cm x 2 of:
((30 + 26.2) - 8) * 2 * 2 * 2 = 385.6 ml
(0.3856 + 8.27) = 8.6556
8.6556 / 7.7 = 1.1241038961039
11.241cm / 112.41mm high which isn't big enough for the driver in question, so it'll have to be whatever the driver needs high, and tuned with sand filling.
More as it comes to hand.
PS, I'd had a few wines before the <> interlude.
Fri Feb 15, 2013 9:27 am
Speaker cut-out is 145.24mm max, plus 20 on each side for bracing (keep it simple for a simple boy) == ID of 185mm
Caps will need to be 300 + 19*2 long, and 300mm wide == 338mm
So, 8 * 185mm pieces @ 300mm wide + 4 * 338mm pieces @ 300mm wide == total of 2832mm + saw cuts, == two pieces to be diced up.
8 * 185 = 1480 + saw cuts
4 * 338 = 1352 + saw cuts
That's a bit awkward.
Sat Feb 16, 2013 12:00 am
Outer dimensions of the box as described above will be 300 x 338 x 225 which isn't quite golden ratio, but is good enough.
225 x 338 will be the front, which sucks, as that'll have the edges of both the top/bottom and sides exposed.
The sides will be smooth with screw holes. And to reduce volume I could inset the back by whatever I want, I guess.
I guess if they don't rape me for cutting fees I could take a few extra small pieces out for bracing internally. But maybe that's not worth it either.
Or maybe the offcuts could turn into a sub box. 4 @ 300 + 2 more @ 338 = a cubic foot and about right for a sealed bass driver.
6 * 338 = 2028
2440 - 2028 = 412 - 32 = 380 == more than 300 (1 out of 4)
2440 - 1480 = 960 - ((8 + 3) * ~5 cut) = fucking near exactly 3 pieces @ 300mm
I guess we'll see what the cutting fees are like! :-p
Sat Feb 16, 2013 12:40 am
Cuts are 50c each, and a little under 5mm wide, which is what I accounted for, IIRC.
Drivers arrived today! A little treat for Fred. So I went out and bought some stainless steel cap screws to match, and a bunch of various types of stuffing to fill the boxes with.
Need to pick up screws, Chinese jigsaw, glue, sliced MDF, and some square pine for bracing.
Also need to do work on the amp, or I'll never hear them...
Tue Feb 19, 2013 5:16 pm
It'll look something like this, I guess, but without the paint:
http://www.loudspeakerbuilding.com/Maga ... 00952,4353
Wed Feb 20, 2013 11:35 pm
Final cutting list:
If taken from two sheets @ 2440:
  • 8 * 185 = 1480 + saw cuts
  • 6 * 338 = 1352 + saw cuts (2/6 for a sub)
  • 4 * 300 = 1200 + saw cuts (4/4 for a sub)
Divided in two, so as to guarantee sufficient material:
  • 4 * 185 = 740 + saw cuts
  • 3 * 338 = 676 + saw cuts
  • 2 * 300 = 600 + saw cuts
Per board @ 2440
If just what I really need:
  • 4 * 338 = 1352 + saw cuts
Need to sort out a hole cutting option. So far a 35 euro ching chong router looks like the best (read cheapest) option. Might try to sort that out today.
Sat Mar 02, 2013 4:04 pm
Went on a mission to charge up car battery and get some bits for this:
  • 4.8 meters of 21mm square pine hand-selected for straightness, check.
  • PVA in a bottle with Poly Vinyl Acetate no where to be seen on it, check.
  • 500 No. 2 pozi-drive 4x40 zinc-plated self-tapping wood screws, check.
  • Medium length No. 2 pozi-drive driver bit for cordless drill, check.
  • Dirty, filthy, cheap, nasty, wretched and Chinese wood saw, check.
  • 1L of alcohol unrelated to this project, check. (can't get a litre of meths anywhere here...)
  • MDF sliced to perfection, FAIL. Another day, I guess.
  • A "fresadora" and appropriate router bit for making round holes cleanly, FAIL. Also another day, I guess.
Dinner time! :-p
Sat Mar 02, 2013 10:06 pm
