View unanswered posts | View active topics It is currently Tue Feb 18, 2020 10:44 am
Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
RGB dashboard backlight, PCB's are in!
Fred wrote:
LEDs overdriven are often extremely bright... for a short time before they fade and deteriorate.
In white LEDs life time is not good at high outputs. Best to drive them softly for longevity.
This applies to usage within the limits, btw. They last _much_ better driven well below their limits.
Thu Nov 08, 2012 10:01 pm
Point taken. It's only proto so I can adjust max current once I know what brightness level is sensible.
FABRICA MI DIEM, PVNC!
Sat Nov 10, 2012 9:25 pm
It's been forever since I last looked at this project and tried to figure out why I couldnt get it to work like expected.
Yesterday I was going over the schematics and the datasheets of the WS2801/3 LED drivers and finally figured it out.
I use a combination of 4 WS2801 (single channel) and 3 WS2803 (6 channel) IC's in series on 1 SPI bus.
In principle you just shift RGB data in for every channel on the bus, and the devices latch to their respective settings.
What I did not pick up on is that both IC's use a different approach to passing data on and latching.
The WS2801's latch on to the first data they receive, and only start to pass data through once they have latched.
So the first 3 bytes sent are used by device nr 1, the next ones by device 2 and so on.
The WS2803 on the other hand passes all received input data directly through on it's output. It latches once you stop sending long enough.
So the first bytes of data pushed in end up being used by the last device on the bus. As you can see, quite the opposite of the 2801.
This had me really stumped.. I just couldnt get the led's to switch in the order I expected.
The order on the bus is 2801-2801-2801-2803-2803-2803-2801.
That translates to the following RGB channels 1 - 2 - 3 - 4,5,6,7,8,9 - 10,11,12,13,14,15 - 16,17,18,19,20,21 - 22
In order to pass data down I think I need to send data in this order: 1, 2, 3, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4.
Will be digging the HW up out of the closet soon to try this out. By now it is only a matter of principle to see if I can get this monstrously
labor intensive design to work. A year after I designed this WorldSemi came out with the WS2812B, which is an RGB pixel with inbuilt controller,
so you can just chain your led's together on a bus. That would simplify the design and assembly of this thing by A LOT.
But I'm not touching my PCB software until I do something usefull with the old board (besides learning from mistakes).
Fri Jun 24, 2016 7:52 am
It's nice when you figure out stuff that has mysteriously been wrong for a long time :-) Good work!
Fri Jun 24, 2016 9:55 am
I think the WS2812B would be harder to get stable since you don't have control over the clk line anymore.
I've got some 2801 and 2803 myself, but also the Tlc5490NT which works fine for now. the TLC has less pins (16 vs 18 at the 2803) but the chip layout is more friendly for my protoboard setups :)
Thu Jun 30, 2016 10:29 am
I've also read that the control of 2812's is slower and more processor intensive (due to bit-banging), but until you've layed
out a relatively small PCB with lots of LED's and a handful of these IC's you cant appreciate the hassle it is to get it all routed together.
The 2812's can be chained together on the bus, and wired up to a power and ground plane... very tempting.
Thu Jun 30, 2016 1:37 pm
I think they are very handy for small designs but I don't know how the signals hold up in a harsh automotive environment :) I hope it works out though, that would be great!
Thu Jun 30, 2016 2:00 pm
