EDIT : Link to thread - http://www.diyefi.org/forum/viewtopic.php?f=24&t=70
Thanks Sean
I've also tried to build them and gotten into few snags.
Ubuntu makes it much easier as the packages are available with apt (i used Feisty).
Alex
Compiling 68hc1x Tools the Easy Way - Comments
Reason: Added link to original after splitting topic.
Re: Compiling 68hc1x Tools the Easy Way
Likewise, I use Debian unstable and its a single press of enter away :-)
I should note here that the executable names are distro dependent, and the default in the MakeFile is the Debian way, so it needs to be switched to the commented out line below for other platforms.
Thanks for your contribution, I'll add you to the (ever growing) list!
Admin.
Admin.
- SleepyKeys
That's why I added this to the script when its done with make install.Admin wrote:Likewise, I use Debian unstable and its a single press of enter away
Admin.
echo "Remember to set
BIN = /tools/bin
PREFIX = m6812-elf-
in Makefile"
No Problem.ababkin wrote:Thanks Sean
Alex
You snooze, you lose!
Excellent, you don't miss a trick do you! :-)seank wrote:That's why I added this to the script when its done with make install.
BIN = /tools/bin
PREFIX = m6812-elf-
in Makefile"
Admin.
Any threads on integrating the tool chain with eclipse?
Hasn't been done by any of us AFAIK, good luck :-)
I use a terminal to build etc and eclipse as a flash editor.
