Resistor noise notes
Place your article links, ideas and suggestions here. A moderator will move topics and posts to the approved area when they meet the standards required. Note, this could take years, and there is a lot of great stuff in this section.
jharvey
1N4001 - Signed up
Post by jharvey »
As found here. viewtopic.php?f=58&t=1218&start=146
The high lights, a 5% resistor can be obtained with specific technologies. 1% resistors costs about the same and use a different technology. The % spec isn't just the long term resistor ratting, but also the short term. Variations will happen as you pump in an AC signal, which will cause a wave of heat across the chip. This wave of heat will cause a wave of thermal expansion, which will cause the resistor to wonder in the 5% range. In an amplifier design(s), this can cause noticeable acoustic noise when driving a speaker. So might as well use the 1% resistors, as they cost nearly the same, and are better.
Here's a copy of Fred's post,
Vishay application note: http://www.c-c-i.com/sites/default/files/vse-an00.pdf
"Carbon composition resistors can exhibit a noise index of 0 dB while bulk metal foil resistors may have a noise index of -40 dB, usually making the excess noise of metal foil resistors insignificant."
http://en.wikipedia.org/wiki/Resistor#E ... rmal_noise
Yes, I realise that it's not really applicable to engine management, but you may as well have the best where you can have them with no downsides including no excess cost :-)
Re: Resistor noise notes
BTW, my old MS2/V3.0 was built entirely with 1/4W packaging, 1/2W dissipation, 1%, MF resistors, even in the locations intended for 1/8W packaging, though I know this is not ideal for vibration resistance. The MF stuff also tends to handle heat better. They're just generally superior, really. Good idea to stash it here. I really should rename this section.
