Author |
Message |
HotCat
I've test OLV on Windows XP with JDK build 1.7.0_01-b08, roughly test 3 engine start scenario log files from Peter, works fine. What a cool tool! I have a USB signal acquisition card, I want to playback the signal captured by the card. Is there a quick way to learn the format of FreeEMS log format? or the only way to learn it through src of FreeEMS firmware and MegaTunix plugin?
Wed Feb 22, 2012 11:23 am |
Joined: Tue Jan 15, 2008 2:31 pm Posts: 15222 Location: Home sweet home!
Glad you like it! :-) The future is bright for OLV too :-) Take a look at src/main/java/org/diyefi/openlogviewer/decoders/FreeEMSBin.java for an example of how to parse stuff. Feel free to add a new parser for your file format on a fork in github if you want :-)
Wed Feb 22, 2012 12:27 pm |
Or just export your data to CSV and use as-is :-)
BenFenner
I was going to say, CSV or tab-delimited files are also supported. That might be easier.
Thu Feb 23, 2012 5:07 pm |
HotCat
OLV cann't handle arbitrary length records, the attachment is my csv file, it only has 1883 records. Is there any way to satisfy my requirement?
[The extension csv has been deactivated and can no longer be displayed.]
Fri Feb 24, 2012 8:23 am |
Works for me! You have a little noise on your VR signal by the looks :-)  Just select csv file filter and load it. Make sure you're on the latest version from github too. Fred.
Fri Feb 24, 2012 2:34 pm |
HotCat
Fred wrote: Works for me! You have a little noise on your VR signal by the looks  It is not the real VR signal from car, it was simulated and exported by PC sound card and then captured by my signal acquirtion card. Quote: Just select csv file filter and load it. Make sure you're on the latest version from github too. Fred. I just test olv 0.02 on two WinXP machine with jdk 1.6 and 1.7 respectively, neither of them works. OLV seems entering a dead loop without saying any last words. Maybe I should execute OLV from last source
Mon Feb 27, 2012 2:45 am |
You should definitely be running from the latest source! :-) Get Maven 3 from their download site and then once working and source up to date, just type "mvn" to build and run it.
Mon Feb 27, 2012 3:14 am |
HotCat
Fred wrote: You should definitely be running from the latest source!  Get Maven 3 from their download site and then once working and source up to date, just type "mvn" to build and run it. It works, Maven is just fantasy. The following is how I am doing with Maven, hope it helps many novices like me Setup your JDK path Attachment:
Setup your Maven path Attachment:
clone Fred's OLV repos Attachment:
Mon Feb 27, 2012 4:07 am |
HotCat
Enter Fred's repos and type mvn, let Maven3 doing the fantasy job Attachment:
It works, no limits on log entries Attachment:
Mon Feb 27, 2012 4:10 am |
