View unanswered posts | View active topics It is currently Sun Apr 05, 2020 8:52 pm
Reply to topic  [ 2 posts ]
FreeTherm & Windows
Hello All,
I can't get FreeTherm 0.6 to run under Win7 x64, but FreeTherm 0.5 runs
I installed the needed files for GTK and GTK# and Mono
My questions are :-
What settings do I use in FreeTherm 0.5 ?
How do I decide the optimum bias resistor ?
TIA,
Dave.
Mon Jul 14, 2014 6:02 pm
IIRC, you need to be running anew unreleased version for some reason.
However, unless you have a nonstandard sensor, you don't need to use it at all.
Choosing a bias resistor comes down to a compromise between accuracy in one place and accuracy in another.
Settings wise, you just need the curve for your sensor(s), and some knowledge of the firmware structure to use the output.
Mon Jul 14, 2014 8:09 pm
