Fix For Not Running On Debian
A thermistor curve calculator and simple code generator program used to develop FreeEMS and generate compile time curves for your custom sensors. Written by Fred and Shameem.
I just tested and this works:
mono --runtime=v4.0 FreeTherm.exe
http://orangesquash.org.uk/~laney/blog/ ... no-gotcha/
I'll try to update the sources to build using the 4.0 stuff so that it works normally from now on, or at least, until they next break it.
Re: Fix For Not Running On Debian
Update, if you build from source it will work now. I just pushed a fix.
