Minor Improvements
A thermistor curve calculator and simple code generator program used to develop FreeEMS and generate compile time curves for your custom sensors. Written by Fred and Shameem.
Minor Improvements
I'd really like the comments to include used parameters from the application such that the file is self contained and you know what it came from. Currently the files checked into the firmware are devoid of this, and it's so long since they were created that I have no idea what I used. I'd also like to create a library of different curves for different bias values (M) and different sensor types (N), IE, M*N files. Putting the values etc into the comments manually would be a pain, and unlikely to be done accurately, better to automate it.
If someone else wants to pick this up and make the change (it'd be easy) then great! Otherwise I'll get onto it before I create the library.
Re: Minor Improvements
Done! :-) Issue closed.
