Daniel Horton's Extreme B6T BFMR Comments
viewtopic.php?f=3&t=932
Post your comments here!
tpsretard
Re: Daniel Horton's Extreme B6T BFMR
Post by tpsretard »
I had a 600ftlbs GTR mazda.
i still have a NEW alex fenshaw transfer diff and a set of straight cut gears for it.
You will be ok with 350bhp 4wd if you use GOOD oil in the box, like light weight shockprofe oil.
but dont dump the clutch.
I broke 29 gearbox's in my GTR.
but that was always with the ALS on or something so.
had full EGR based ALS :)
wrcbfmr
Re: Daniel Horton's Extreme B6T BFMR Comments
Post by wrcbfmr »
yeah should be okay, as you said no launching, or anything stupid. already been through a few sets of third gear, current box is on its way out too, will be putting another in with an end plate mod, then start looking at doing the celica gearbox conversion
tpsretard
Post by tpsretard »
The celica is the the way to go.
Cant brake that sucker. i sold mine before that came out and bought and STI.
I do miss the mazda though. but who would not with just over 500bhp and around 600ft lbs of TQ
was with VP 109 fuel and 40psi from an IHI rx6 turbo
gurov
Post by gurov »
is your plan to use the base board and plug a freeems into the 40 pin for testing for this car, but eventually send it away with ms2 ?
might be kind of interesting to have an adapter harness for a quick "unplug ms[123] from 2.2/3.0, plug freeems in" as well as offering your own shield board.
2004 BMW 325XI Turbo - ms3x- ls1 cop, seq fuel
2004 Nissan SE-R SpecV Turbo - ms3x - seq fuel, seq spark, j&s safeguard using stock qr25de crank/cam signals.
1994 Toyota Supra Twin Turbo - ms3x - seq fuel
http://msvarchive.com
There are no plans for FreeEMS on this vehicle at this stage.
Response from Matt at DIY Auto Tune.
Hi Fred,
I'm kind of mystified about the bit of plastic tubing in your kit, too! It isn't normally something we include with the kit. I couldn't even find any tubing that looked like that on our shelves. My best guess is that you're looking at a bit of stray packing material there, as we tend to re-use packing material from items sent to us and sometimes some really weird things get in there.
The spare zener diode is for the few people who still trigger off a coil negative - it is mentioned in the build guide, but it's in a step most people skip.
About the harness - different people have different preferences there, so we try to offer a couple of the most popular options and provide people with the information they need to make an informed decision. For those who prefer making solder cup harnesses, we sell the wiring on its own without the connector, and the solder cup connector is included with the kit. We've maintained the selling the wiring on its own with the new MS3 harness as well, with slightly under 1/3 of our customers favoring this approach.
Our goal with the harness was to come up with the most reliable harness we could mass produce. We didn't see a good way to meet that goal with a soldered connector as they are time consuming to solder and ensuring the connection will hold up under vibration is pretty difficult. A couple years ago, we did have a couple of improper crimps at the D-sub, but we were able to tighten up the quality control on them and the problem hasn't repeated itself. And we haven't seen any reports of the harness itself fail. We feature the details about the harness - including the use of crimp connectors, what pins are used, and the wire gauges - on our catalog page, so customers can see if it fits their needs.
Thanks,
Matt Cramer
DIYAutoTune.com Support
Please quote your email when you reply, as this will help me look up our conversation and respond to you faster.
Nice, hope he posts updated pictures and videos. Will keep an eye our for those, would be interesting to see, but not required if it prevents dev time. Just eager to see.
tpsretard
Post by tpsretard »
I do not mean to be negative but i smell a blown gearbox,
It is why i got rid of mine, i went through 29 gearboxes and 2 dogbox's :O
But if it dos i have some build tips for you all and some parts too :)
tps, don't be silly, we have to lower it down off of the jack stands first ;-)
