View unanswered posts | View active topics It is currently Tue May 21, 2019 12:35 pm
Reply to topic  [ 92 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9, 10  Next
Fred's 1987 16v B234F Powered Volvo 240 GL Sedan
EDIT: Made myself some walking space: https://mobile.twitter.com/FredCookeNZ/ ... 9528965120
Tue Aug 08, 2017 2:43 am
Removed the spare tyre well and panels above the mufflers tonight, after clearing out the garage. Now I have a lot more space. Good timing, more shit arriving tomorrow. Need to crack on, though. KP60 needs to come home, and Suzuki does too!
https://twitter.com/FredCookeNZ/status/ ... 2866258944
https://twitter.com/FredCookeNZ/status/ ... 3183191041
https://twitter.com/FredCookeNZ/status/ ... 0387044352
https://twitter.com/FredCookeNZ/status/ ... 9467195393
https://twitter.com/FredCookeNZ/status/ ... 1724295168
Fri Aug 25, 2017 1:23 pm
Relevant: viewtopic.php?f=3&t=2627&p=43817#p43817
Fri Sep 08, 2017 7:49 pm
The money shot: https://twitter.com/FredCookeNZ/status/ ... 5763841025
Mon Sep 11, 2017 11:57 am
Went and picked this thing up from the side of the road earlier and gave it a bit of TLC: "new" (out of the 240 wagon) spark plugs! :-D
Pulled the old ones out and found one normalish, but sooty, two very sooty, and the final one not combusting and oily.
Also got under the BMTroubleYou and found the arse end of the trans and marked where to give the body the chop.
Tweets/pics:
https://twitter.com/FredCookeNZ/status/ ... 6966277120
https://twitter.com/FredCookeNZ/status/ ... 9891357696
Sat Sep 16, 2017 9:33 am
BMW getting in the way, BMW getting a leg up to be out of the way: https://twitter.com/FredCookeNZ/status/ ... 7927838720
244 out and about, in actual use for the first time, took it to work and back freshly re-legal:
https://twitter.com/FredCookeNZ/status/ ... 8906840069
https://twitter.com/FredCookeNZ/status/ ... 9789739009
Fri Sep 22, 2017 12:37 pm
Moved the BMW over 20cm tonight: https://twitter.com/FredCookeNZ/status/ ... 7967117312
And asked a man about a dog, and he said: Exhaust is one piece, unbolt at engine or cut off. Roger. Will do.
Wed Sep 27, 2017 9:37 am
A few updates for this thread:
1) Reason the V12 wouldn't start last time I tried: no fuel. Went to pump out the tank today and it ran dry for a while blowing air. Killed the power and moved on to other tasks.
2) Took it out for dinner last night. Wife drove home. Wife drove herself to yoga this morning in it. Revved it a bit much a few times. I drove back from yoga. Then I took it to the hardware store. On the way home the knock got a LOT worse :-D oh well.
https://twitter.com/FredCookeNZ/status/ ... 4238588928
https://twitter.com/FredCookeNZ/status/ ... 0512430080
https://twitter.com/FredCookeNZ/status/ ... 3804297216
https://twitter.com/FredCookeNZ/status/ ... 8150972416
Sat Nov 04, 2017 11:35 am
Spent some time on the BMW destruction last night. Got it up in the air, and left exhaust cut, and some fuel bits partially pulled.
Tweets:
https://twitter.com/FredCookeNZ/status/ ... 8327318528
https://twitter.com/FredCookeNZ/status/ ... 7626128385
https://twitter.com/FredCookeNZ/status/ ... 6133540864
https://twitter.com/FredCookeNZ/status/ ... 1042985985
https://twitter.com/FredCookeNZ/status/ ... 5678585857
https://twitter.com/FredCookeNZ/status/ ... 8830209024
https://twitter.com/FredCookeNZ/status/ ... 1379208192
https://twitter.com/FredCookeNZ/status/ ... 4348168192
https://twitter.com/FredCookeNZ/status/ ... 4219101186
Pics:
Wed Nov 08, 2017 10:08 pm
Finally got the garage cleared up behind the BMW carcass. Volvo engine fully stripped and relocated. Most stuff put away where it belongs. So I was able to progress the BMW killing a little in preparation for more tomorrow! :-)
https://twitter.com/FredCookeNZ/status/ ... 3874807815
https://twitter.com/FredCookeNZ/status/ ... 9614942208
https://twitter.com/FredCookeNZ/status/ ... 5350779904
https://twitter.com/FredCookeNZ/status/ ... 6584313856
https://twitter.com/FredCookeNZ/status/ ... 3190804481
https://twitter.com/FredCookeNZ/status/ ... 4108272642
https://twitter.com/FredCookeNZ/status/ ... 5477880833
https://twitter.com/FredCookeNZ/status/ ... 6465700865
https://twitter.com/FredCookeNZ/status/ ... 2491659264
https://twitter.com/FredCookeNZ/status/ ... 1202308096
Tomorrow's plans, and the weekend's plans:
0) Remove 02 sensors from driver's side
0.5) Possibly be forced to remove driver's seat before 1
1) Cut other exhaust at the merge point
2) Remove all under-car plastic shields
3) Remove entire exhaust from merge backward
4) Wedge/jam front wheels so they can't roll
5) Remove fuel lines and/or tank after lifting body in the air
6) Disconnect brake lines from rear end
7) Disconnect anything else from the rear end
8) Lower entire rear subframe out of the shell
9) Remove seats from floor pan
10) Pull wiring forward and out of the way
11) Cut the rear off of the front
12) Cut rear into smaller pieces and put in the trailer for recycling
13) Find a place to put the rear subframe, diff, brakes, wheels, tyres, tank, etc.
14) Condense the remainder down until the KP60 can come home for repairs and WOF
Or something like that. Gotta get my KP back! :-)
Thu Nov 23, 2017 11:33 am
