View unanswered posts | View active topics It is currently Tue Jul 07, 2020 4:07 am
Reply to topic  [ 119 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
Fred's 1983 KP60 Toyota Starlet, take 2!
Done and on top of all of those things, I flushed out the brake fluid through both front calipers! I should whip the back wheels off and bleed the rear cylinders/lines, too, but not today! 3 hours spent on her today :-)
EDIT: And when I pulled the cap off of the radiator it had brown sludge on it! I thought for sure the head gasket was gone, but then I touched it, and it appeared to be dust-air bubbles and was instantly soluble! Definitely not oil. How weird. Didn't nab a photo, but it looked pretty ugly in a minor sort of way.
A few tweets from yesterday and today:
https://twitter.com/FredCookeNZ/status/ ... 3078521857
https://twitter.com/FredCookeNZ/status/ ... 1933285378
https://twitter.com/FredCookeNZ/status/ ... 5593081856
https://twitter.com/FredCookeNZ/status/ ... 9627404288
Pics:
On with the panels/rust/rust-proofing/etc! Then reassembly of the front end and off to the back to take care of the roof corner, somehow. May involve a professional to help with that, or not.
Tue Jan 24, 2017 9:03 am
Rolled it forward, jacked it up, pulled off the rear wheels, and bled both sides through. All nice and clean now.
Wed Jan 25, 2017 12:36 pm
Decided to go down and do some measuring tonight:
Ref: https://twitter.com/FredCookeNZ/status/ ... 7820109825
Looks like a 280mm rotor is about max with those big calipers inside that little 15x6 feather-weight Honda wheel.
Need to suss out the caliper mounting and an appropriate disk for it. 260-280x30 likely means I'll be using a blank and alloy hat. Or I could find some ordinary FC or FD ones that take 22mm disks to keep the weight down? AP do a 267x28 blank, or in the 280mm diameter it goes up to 25.4mm thick. Maybe I should find some 22mm calipers instead and save the big mitsu ones for something else. It'll depend on how the caliper can be mounted as to which diameter is most suitable. The above shot only shows the maximum outside placement of the caliper within the wheel, and not what it might attach to on the vehicle.
Once I know the disk arrangement then I can get some quality spacers/adaptors made up to mount the wheels and get some decent rubber under it.
Which will mean some sort of lowering job, or it'll look silly. Which will mean I put some thought into front-end suspension geometry and components. My how it snow-balls! :-)
Sat Feb 18, 2017 11:38 am
Bought a bonnet and hatch for this thing, both without any rust, unlike mine.
My bonnet has rusty reinforcement structure, which I'm dubious about passing a WOF with. I'll likely swap on the new one for WOF then the rusty one for driving with the colour match.
My hatch is mostly good, but has some bubbling under the seal that would require dealing with eventually. For WOF purposes I'll just peel them back and scrape out the rust so they sit down normally.
Longer term I'll use one of each for making some ultra light-weight carbon replacement parts. Maybe. :-p
Pics:
Sat Feb 25, 2017 11:01 am
Bought these for the old girl, not super low, just lower, and they're on stilts stock.
Should sit nicely, I think. Says 25-30 or 25-40mm drop, and that's roughly half of the gap
between tyre and arch at the moment, which will change the look significantly and probably
make it corner a bit flatter, too, assuming they're also stiffer. Stock was a wee bit soft... :-)
Older shots for context:
Fri Apr 07, 2017 9:48 pm
Better shot of the springs from the other night:
https://twitter.com/FredCookeNZ/status/ ... 3458445312
Thu Apr 20, 2017 4:19 am
Unburied this thing last night and gave it a run and a full tstat-open warm up. Tonight I'll do the same for the BMW and try to put some of the panels back on this thing. Needs to look respectable for various reasons. Keen to make some progress on it again. Miss driving it.
Three hours later here we are and the KP60 is safe and dry in a new different garage, and the BMTroubleYou is in its place. TroubleYou for a reason. See other thread...
Fri Jun 30, 2017 8:07 am
And tonight the 740 sedan towed it to yet another garage that was previously filled with large amounts of native wood. Temporary home:
https://twitter.com/FredCookeNZ/status/ ... 1531281408
Sat Jul 08, 2017 10:19 am
Have a zero rust bonnet and near zero rust hatch for this thin in my possession now :-)
Will snap some better photos soon, but for now, these will do: https://twitter.com/FredCookeNZ/status/ ... 4044661760
Sun Jul 23, 2017 9:31 am
Agreed on and paid for half a Toyota Carib today/the other day. Pick up on Sunday morning :-)
Why? Panels for slackercam and the 7AFE engine and possibly the diff/rear suspension (if it's IRS) for me/this.
Anyway, 100 bucks is worth it for the options it provides :-)
https://twitter.com/FredCookeNZ/status/ ... 8957248512
Wed Nov 29, 2017 8:07 am
