View unanswered posts | View active topics It is currently Sun Jan 20, 2019 10:46 am
Reply to topic  [ 113 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12  Next
Took it for a WOF today and it failed on a few things, and got warned on a few more:
1) left tie rod play
2) front pads all but gone
Warn:
3) mufflers dodgy/leaking
4) tyres have camber wear
5) exhaust mount broken - trip to pickapart sometime soon
Things I noticed:
1) Rust in bonnet and a few other places appearing
2) ATF leaking underneath, not sure where from, but this is ending up on the exhaust, hence smoke on a few driveway climbs - maybe out breather under heavy load from expansion?
So aside from the immediate ones, I'll need to architect and build an exhaust, or part thereof, to fit this car. Therefore 3" is going in, hopefully fairly quietly. Got 6 months to sort the minor stuff out, including that.
Mon Jan 22, 2018 12:23 pm
Got it a WOF some days ago, and have begun planning the new 3" turbo-ready exhaust that needs to be completed inside the next 5 months or so.
First up, my OnePlus 3T with cover is 153mm long and 77mm wide. Why? Read on.
Rear muffler available space measured by super accurate cell phone dimension fractions:
1 length + ~3cm depth/height at rear = ~183mm
3 lengths long = ~459mm
2 lengths + 0.5 widths wide = 306 + 38.5 = ~344.5mm
Under subframe clearance measured the same way:
1 width + ~1cm = ~87mm, only need 76mm so this is ample without affecting clearance or risking heat damage.
No measurements on the middle muffler or catalytic converter area for another muffler and a resonator/coby, respectively, yet.
Plan is to do minimal joins/welds and start the 3" part as rearward as possible. The muffler WOF man complained about is the middle one, though, so it's going to get most of an exhaust.
I'll probably just put a 3" size flange onto the stock exhaust up in front of the middle muffler and post catalytic converter and have it step up there or something like that.
Goal is as quiet as possible for the space available with no restriction for later RB30DET use.
Sat Feb 10, 2018 4:31 am
Middle muffler, which actually failed measures:
length x width x height
350 x 250 x 100 offset/centre config (centre at rear, offset at front)
But the car could accommodate:
400 x 350 x 125 max same config
There's a stainless steel glass packed perforated in that config in this size:
330mm X 230mm X 100mm which is smaller than stock.
But I'd prefer to go up in size, or stay the same, not go down.
Tue Feb 13, 2018 12:14 pm
Modified car life:
  • Needs mufflers
  • Buys gearbox
Manual setup purchased, should be delivered this week: https://twitter.com/FredCookeNZ/status/ ... 6286559232
Seller said it has 91,000km on it. Components:
> RB25det Neo push type gearbox
> 9 bolt flywheel
> clutch cover and clutch plate
> flywheel bolts and cover bolts
> front and rear drive shafts
> bell housing bolts
> sandwich plate
> clutch and brake pedal
> slave and master cylinders with uncut line
Wed Apr 11, 2018 1:24 am
Shipped out from Chch today. May arrive with me tomorrow, or over the weekend, or early next week. Not sure. Expecting a phone call to say "collect" at which point I'll swap cars, and do just that.
Thu Apr 12, 2018 12:02 pm
No arrival as yet, so I got stuck into tidying the garage tonight, and in the process stumbled upon a big fat RB30E engine sitting in a corner.
So I loosened the head bolts/cap screws one by one, and drained the dregs from the sump and removed the filter and intake manifold brace, and cleaned the top of the cam cover for photos soon.
Hoping to engage Corbon/Rob for some RB30E support development prior to decommissioning the distributor, coil, head, inlet, etc and selling the lot.
Also measured up the front diff in the 4wd sump that I bought some time ago: 25 splines and R160 size (at least, R180 ring wouldn't fit in that casing AFAICT).
Hoping to stuff some sort of torsen or viscous Subaru centre in it before it goes in the car! :-)
A few pics:
https://twitter.com/FredCookeNZ/status/ ... 1415669760
https://twitter.com/FredCookeNZ/status/ ... 9076040704
https://twitter.com/FredCookeNZ/status/ ... 8795355136
Fri Apr 13, 2018 12:40 pm
Rang the freight company and it's on a train! What a life it's had and I'm yet to even see it :-D
Going to potentially try to figure out the Subaru R160 LSD situation in a little while, hopefully. Also R180 investigation for the KP60.
Sat Apr 14, 2018 3:02 am
Picked the gearbox up yesterday at lunch time and brought it home last night. Used my crane to unload it and my old jack to roll it into the garage - too heavy to carry! :-D
Clutch cooked, but PP and flywheel surfaces in great shape indicating the mileage was legit.
All gears select and transmit hand-torque.
Will have to get an endoscope and check out the guts before it gets filled with oil, but I'm hopeful :-)
Clutch is pull type, too, not push, so that's a bit novel for me. Just needs a new disk, hopefully I can find one like the stock one which is ultra high quality even if totally worn out (9 rivets, 12 springs, nice pockets).
Mon Apr 16, 2018 8:34 pm
R160 is fluid lsd , why you use that? Also it has high gear ratio , is that suitable for your project?
Tue Apr 17, 2018 7:38 pm
Hi wastegate! I thought there were clutch pack R160 options? If not, it's not an option for me. Torsen might be, but I prefer clutch pack diffs. Same goes for this Nissan, too.
3.9 is the ratio that I want for Starlet as shown in some earlier page of the Starlet thread you also posted in :-)
Fri Apr 20, 2018 6:16 am
Users browsing this forum: No registered users and 5 guests
