View unanswered posts | View active topics It is currently Tue Jan 23, 2018 11:01 am
Reply to topic  [ 91 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
All ready to rumble, minus the 12mm ratchet ring which is hiding from me for the time being. Probably don't need it anyway. < Typed? Last night and forgotten, I think, posting now out of sequence!
Tue Apr 04, 2017 11:01 am
I went out of my way to get this head because it was quite clean, just a light
varnish, no sludge at all. Japanese engines are rarely this clean, for example
there was another RB25DE there that was coated with black carbon deposits
about 1-2mm thick, everywhere. Not a fan of engines this grubby, but most
are. So to see this one with only yellow stains in some parts of the top end
was a pleasure, and I thought about grabbing it there and then, but there
wasn't time and I didn't have all tools required with me.
https://twitter.com/FredCookeNZ/status/ ... 6785292288
https://twitter.com/FredCookeNZ/status/ ... 3469455361
https://twitter.com/FredCookeNZ/status/ ... 8041651201
https://twitter.com/FredCookeNZ/status/ ... 1282191360
https://twitter.com/FredCookeNZ/status/ ... 9733224448
https://twitter.com/FredCookeNZ/status/ ... 9061654529
Missing a few things, like cam cover tin that's not bent, and coils/brackets for
them, etc, but fundamentally, this is a good base for the 600hp RB30DET goal :-)
Figured out the original purpose of the switch in this thing:
https://twitter.com/FredCookeNZ/status/ ... 4837328896
リモゴンスターター
メイン
remote starter
main
Done by visually matching the letters to those in random wikipedia pages and copying them into the sequence, then through google translate.
Wed Apr 05, 2017 12:06 pm
Waiting for the wife this evening, I pulled the panel off, identified the
plug/socket combo, disconnected it, did the brakes N times quickly,
and the flashing 4wd light came up. Tested shortly afterward there
was a puff of smoke and away we went with some squealing. Good.
So then I dropped off the mrs at home and went and found a dark
quiet place to perform a more entertaining and extensive test. OK.
One small white cloud and away I went, slightly satisfied at my
first NA RB powered burnout since 2007. Nice.
I can do better, I wrongly thought. And went off to find another
dark quiet street to retry in, this time locking into a low gear so
as to hold the smoke up the street longer. No dice. Excess grip.
Strange. Then again, both spun, rotating toward the footpath I
was. But strange noises were occurring.
Then I realised that the right rear had gone flat and proceeded
to dawdle home at a crawl to preserve the slightly tortured tyre
sidewall. Made it. Tyre looks OK. Needs air, and likely a puncture
repair and balance, too. Carnage: https://twitter.com/FredCookeNZ/status/ ... 1259177984
So then, new priority for this car, LSD :-) Though I could have similar
amounts of fun with either of the Volvos with addition of the G80, too.
Wed Apr 26, 2017 11:30 am
Fixed this last night and refitted it. Need to source an LSD for this so I can have some proper
circular fun in it, like the old days, but with 45 more horsepower and 300 more kilograms.
Holy tyre, batman: https://twitter.com/FredCookeNZ/status/ ... 4755595268
Wed May 03, 2017 10:42 pm
This thing did 350km this evening, in 4 hours 36 minutes, that's a 76kph average, peak maybe 125 or so? Not sure.
Pretty bad conditions, was mostly aiming for safe arrival.
https://twitter.com/FredCookeNZ/status/ ... 6093072384
Fri Jul 21, 2017 2:03 pm
And another 360km today, in 4 hours and 9 minutes, average of 86.747 kph, non-stop, except topping up one tyre on the way out of town.
And it's ~1k overdue for an oil change, assuming I put ordinary stuff in. 236642km now, last changed at 230740km just over a year ago.
Obviously not putting a lot of miles on this one! But it does most of the big road trips because it's a safer car, especially when wet.
Next stop, new block of land for some measuring and marking :-)
Was good to catch up with Presto and his Mrs: https://twitter.com/FredCookeNZ/status/ ... 2306757633
Sun Jul 23, 2017 9:28 am
Finally got around to modifying this in a key way, earlier, in the cold, and rain, outside, in the dark, sub-optimal conditions for soldering, but:
https://twitter.com/FredCookeNZ/status/ ... 1014703104
Also had the right rear tyre fixed again on Monday arvo while feeling like crap. Hopefully it holds out for 500km or so, at least.
Tue Sep 05, 2017 12:51 pm
My Stagea, the workhorse of the stable: https://twitter.com/FredCookeNZ/status/ ... 3781744640
BMW sunroof is on its way to a new owner :-D
Fri Sep 08, 2017 7:48 pm
Motherfucker (singular) stole my wheel! Neighbour has footage of it - took the idiot over an hour to steel one wheel. Mostly walking to/fro his probably flat-tyred car. Occurred between 2am and 4am on Sunday morning. Nearly 48 hours ago, now.
All I have to show for it is a bald snow tyre on a mismatched wheel (ones I used to have on the Lantis) and 5 new blocks of untreated pine! :-/ Skinny tall white guy. Shorts tshirt. Sounds like a Nissan Silvia/Skyline owner to me.
https://twitter.com/FredCookeNZ/status/ ... 7485487104
Mon Sep 25, 2017 1:13 pm
