View unanswered posts | View active topics It is currently Sun Jan 17, 2021 7:25 pm
Reply to topic  [ 114 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
Title to be edited one day when I finally pick up a Stagea to do these things to after dreaming about it since the mid 2000s...
Since then I've gradually been collecting things for this project. I have a list of stuff that I've got, and a list of stuff that I need.
Rough description of end product
Slow-looking station wagon (not cop bait) with ~600hp built RB30DET, manual, reliable 4wd driveline, decent brakes. Summary: Ski trip weapon. Capable of going fast up a mountain on slippery surface full of gear and people and so forth.
Stuff I've got
  • GTR intercooler (same as my truck)
  • R32 GTR wheels, forged, 16x8
  • RB30E engine as a base for an RB30DET! Viewed, paid, and collected.
  • 1998 Stagea 25X Four, in white! Deal cut 5th May, 7:20 pm. Paid, dropped off, ~9pm 6th May.
Stuff I still need
  • Holset HX52W turbo
  • GTR gearbox/transfer case
  • Brakes, depends which base vehicle I get
  • All of the little things you forget about, pumps, injectors, hoses, etc etc.
And, of course, the car! Not sure what sort of spec to go for, but these are commodity and always have rusty front doors. Reshelling would be inexpensive if necessary after a big fuckup. Hence this comes last, after all of the goodies needed to make it how I want it to be.
Thread started because I just pounced on an engine deal this morning. Listed last night 6:45pm, search email came through 1:41am, when I opened it this morning 80 views already. Paused for 10 minutes unsure, then thought about it, and hit buy now to take it off the market. These things are getting rare, this is the first one that's come up worth buying in 2.5 months of searching. Even if I'm forced to sell it later if I lose work or whatever it'll probably be worth what I paid, or more, to sell again.
EDIT: See page 2 for photos from the auction! :-D https://twitter.com/FredCookeNZ/status/ ... 9156555780
Fixed title, added car to list :-D
Sat Sep 26, 2015 9:43 pm
Engine inspected! 126k km on the clock, silky smooth running, and not overly grubby inside. Perfect for my needs! Also comes with enough extras to sell for half what I paid, probably. As a result, this RB30E won't owe me very much at all once I'm all clear of it :-)
Sun Sep 27, 2015 8:49 am
Dash shot of mileage: https://twitter.com/FredCookeNZ/status/ ... 4036445184
Mon Sep 28, 2015 8:00 am
Fred wrote:
  • Pending: RB30E engine as a base for an RB30DET, should view today, moved into storage "soon"
Edited to reflect tonight's pickup! Engine is in hand, in garage, and ready to be turned into a monster when the time comes! :-)
Pics + story + bragging:
https://twitter.com/FredCookeNZ/status/ ... 4269957120
https://twitter.com/FredCookeNZ/status/ ... 6173254656
https://twitter.com/FredCookeNZ/status/ ... 9100370944
https://twitter.com/FredCookeNZ/status/ ... 8242527232
I feel a GIF coming on...
Tue Oct 06, 2015 10:57 am
Attached RB30 PDF made by Skylines Australia Forum. Good reference for a start.
Things I can think of right now:
  • Check the block face where the stock RB30 idler mounts is machined flat or cast. If it is cast you have to make up a spacer/metal putty it flat so when you fit a tensioner for the dohc head it aligns with the belt properly.
  • Apparently on some RB30s the turbo oil/water feeds for the turbo on the exhaust side are blanked off and not drilled, so will need to be done.
  • If you go with a VCT head (ie not R32 or RB26) then you need to block the VCT feed in the face of the cylinder head and supply the VCT with an external feed. You can drill out some plug and feed it internally but I have seen some people say it didn't work...
The PDF has heaps of good info. Will add more as I come across it.
rb30_dohc.pdf [285.09 KiB]
Downloaded 796 times
Fri Oct 23, 2015 9:08 am
I feel as if someone is about to post here, so I'm going to quickly add this: https://twitter.com/FredCookeNZ/status/ ... 1366820864
And this came out: https://twitter.com/FredCookeNZ/status/ ... 3394971648
And only this was left: https://twitter.com/FredCookeNZ/status/ ... 7538973697
And it was this clean in the trans: https://twitter.com/FredCookeNZ/status/ ... 4294827008
Looking forward to the next post! :-D EDIT, damn, he beat me to it! :-D
Fri Oct 23, 2015 9:16 am
Definitely has the oil feed and return, though the feed block off is a bolt that's not fully cranked down (must be bottomed out to block it, I guess). Looks weird. Might head down and take a look at the coolant point, and maybe pull some plastic off to view the tensioner location, too, if I CBF.
Fri Oct 23, 2015 9:40 am
Oil: https://twitter.com/FredCookeNZ/status/ ... 3077404672
Coolant: https://twitter.com/FredCookeNZ/status/ ... 2897193984
Looking under the belt cover = too hard for 10pm after a long day that started at 5:45.
Fri Oct 23, 2015 10:13 am
Sweet, the blanking bolts are all there. I have heard of that oil feed one not being drilled through to the gallery under the bolt though so check it out when you can.
http://www.sau.com.au/forums/topic/247912-drilling-and-tapping-feedreturn-in-series-1-rb30-block/
Fri Oct 23, 2015 10:41 am
Good tip, thanks! Will check this out soon :-)
Fri Oct 23, 2015 11:21 am
Users browsing this forum: No registered users and 5 guests
