View unanswered posts | View active topics It is currently Tue Feb 20, 2018 9:01 am
Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
"89 Nissan Patrol Y60
Fred wrote:
ATF fluid? Don't you mean EP or moly grease?
I've been trading emails with Warn costumer support, they recomended moly grease on the shaft and some special oil on the gears, they said that auto trans fluid also works. Most guys here just use engine oil.
Fri Dec 28, 2012 11:57 pm
So I made a boo boo when re assembly and the last planetary was upside down, but I could only notice when actually trying it.
The mud on the gears was some much that it was almost impossible to know the correct sides. :oops:
Everything works nice and smoth winch-wise.
The electrical controller is way too messy, I shall take it apart, rebuild and document it.
Mon Jan 07, 2013 2:22 pm
My turbo compressor is drooling.
This is a problem that needs to be tackled. Open to any kind of ideas and sugestions.
Mon Jan 07, 2013 3:24 pm
For all the wiring I plan to use the following Molex Connectors:
501820-3201
64334-0100
64319-3211
They are all sealed and compact wich is awesome to bring the wiring to the engine bay.
Wed Jan 16, 2013 11:17 pm
I will use these locally available waterproof connectors, they're a pain in the arse to wire up, but everyting is rubber sealed.
I really don't want to overlook this, its not fun to discover that dirt and other gunk is draining electricity from the circuit.
Mon Jan 21, 2013 1:39 pm
The rear locker takes way too long to engage that could be.
1) Vacumm lines - After 23 years of life the rubber can't be perfect, it might be leaks or dents and other age related trouble.
2) The solenoid valves - These are a problem, they just suck, don't have enough power and age makes it worse. Its a money saving move, they have 2 solenoids instead of a 3 way one. These will be replaced by an industrial grade 3 way-one, no need for the disengage solenoid to be "always on", its a poor design.
3) The locking pin gear is getting worm out - The gear theeth might getting worm due to engaging the locker while on movement (altough I doubt this locker was barely been used before) and 2) and 1) might also cause this.
4) There is water on the vacumm pums - I doubt this one, just because I doubt the previous owner actually used it offroad, it worths checking tough.
Any recomendations for a 3-way solenoid valve ?
Tue Jan 22, 2013 1:10 am
Guys I need sugestion.
I am trying to get a wideband kit. The obvious option is the Innovative MTX-L
It uses the Bosch LSU 4.2, it has controller built in the gauge, analog output, and the controller supports diesel.
I am also finding great prices on ebay for it.
Any feedback on those ?
Thu Jan 31, 2013 2:54 am
I just bough 2 Map Sensors a Freescale MPX5700AP what a good price !
And some Vishay BC Components what a steal. This will get me IAT.
Thanks heintaixp for the link.
Thu Jan 31, 2013 3:27 am
Wideband: http://www.14point7.com/
Alan's a good guy. DeuceEFI has a spartan. I have a couple of SLC OEMs, as does Peter.
Thu Jan 31, 2013 9:03 am
Thanks, I mailed toalan, and the controller is only built to read to 10 to 20 AFR, i need way higher values.
Also thanks for the sugguestoion of using the SLC OEM to get the raw data I love it, altough I need to manage time, so I will go with the Innovative for the time being.
Fri Feb 01, 2013 2:14 am
Users browsing this forum: Baidu [Spider] and 5 guests
