Mikes 1987 Chevy Camaro - Comments thread
malcom2073
Post by malcom2073 »
This is the comment thread for my Build Thread
Peter
Re: Mikes 1987 Chevy Camaro - Comments thread
Post by Peter »
Welcome,
MAF - Haven't done enough research to know which one I should use with this sytem, but both are an option.
A MAF sensor input isn't supported by FreeEMS at this time.
Tachometer output from 7 pin HEI module
I don't know what you're planning on doing with this, but I don't think you can use it as your trigger wheel unless you're planning on using throttle body injection.
Narrow and wideband o2 sensors.
I don't think narrow band sensors are supported, because they aren't very useful. I use this wideband controller.
Injectors (Two banks of 4, batch fire. Sequential eventually?)
Have you seen/read this? viewtopic.php?f=54&t=1084 I'd recommend semi-sequential for 8 cylinders.
Fortunately, as a reference I can use the megasquirt documentation
I've read a little bit of their documentation, and it's pretty terrible in my opinion.
Some other things you should probably read.
viewtopic.php?f=9&t=1666
viewtopic.php?f=41&t=1699
http://issues.freeems.org/view.php?id=190
Good luck,
Peter
:-p
Peter wrote:A MAF sensor input isn't supported by FreeEMS at this time.
True, just log this for now, pretty easy to add support for, though.
Good point. Using that, you'll need to hack in yucky MS style untimed long injection batch/bank setup. Yuck. OR, inject 4x per revolution, which is doable, but only if your injector config is perfect. Otherwise it'll give you trouble too. Put a 12-1 16-1 20-1 24-1 on the crank and call it a day? 36-1 is usable too, but only to about 5k RPM at this time. Optimisations later will increase that by at least double likely more.
+1 :-)
+1 very verbose to the point of losing you. Flaky in other areas. Misleading in others still.
Thanks Peter :-)
malcom2073
Peter wrote:Welcome,
Thanks!
I'm still going to plan for it in the system as a "nice to have", at least for datalogging. Who knows maybe I can help implement it (yeah right, don't think I'm THAT good)
Yeah I have to track down DeuceEFI and see what he did.
Sorry, I meant I had a wideband controller that outputted both. Didn't know if NB would be useful, but that's easy to not use.
That sounds like a better option, thanks for the link!
I'm still doing my research :)
Thanks for the links, I've found those and have them bookmarked for reference :)
Dan
Post by Dan »
can i also suggest taking a look at the RavAGE schematics?
malcom2073
Dan wrote:can i also suggest taking a look at the RavAGE schematics?
After doing more searching, I've got that one saved from gitorious too to look at :)
malcom2073
Assuming I can figure out how to open Altium Designer files...
DeuceEFI
Post by DeuceEFI »
+1 on the RavAGE schematics, those are what the Jaguar board is based on :-)
Can I suggest, for a third time, our friend Kenny in HK:
viewtopic.php?f=67&t=1694
He may be happy to sell you one of his spares and post it.
This assumes building a BDM first and fine pitch soldering, which a TA approach does not require.
Kennybug
Post by Kennybug »
Yes. I have spared board. :lol2:
The quality may not as good as Andy's Silver circuits boards. But they are just useable.
Each cost around USD 4 from Shenzhen.
Anybody needs them, please PM me your name and address.
I will help check the cost of air mail :lol:
