View unanswered posts | View active topics It is currently Fri Feb 22, 2019 1:58 pm
Reply to topic  [ 9 posts ]
Andy's 1997 Ford Mustang 3.8L V6 build
I brought home a 1997 Ford Mustang with a 3.8L V6 with the following:
EDIS
Alloy heads
Headers
X-pipe
Unfortunately it has a 4r70w 4-speed overdrive automatic transmission so I will need to figure out how to control that once the factory ECU is removed...
Unfortunately the engine only made it 20 miles out of the 80 mile trip home before the P.O.'s head gasket replacement job went bad. I will post to this thread as the engine rebuild happens along with the change-over from Ford factory ECU to FreeEMS with one of my Jaguar A3 boards.
Please post your comments in this comments thread: viewtopic.php?f=3&t=1611
EDIT: X-pipe was H-pipe
http://www.coolefi.com
Mon Feb 27, 2012 10:58 pm
Here's a photo in the driveway :-)
File comment: 02/2012
Mon Feb 27, 2012 11:00 pm
Unfortunately I'm in a legal battle with the previous owner over the title to this vehicle... :-(
Hopefully I can get this sorted out soon...
Thu Aug 09, 2012 1:48 am
Thu Aug 09, 2012 10:45 am
Woo Hoo, I now have the title to the Mustang :-)
Sat Aug 11, 2012 4:40 am
Sat Aug 11, 2012 12:06 pm
Ok, after replacing the both lower ball joints, both struts, the inner and outer tie rod ends on both sides and having the car aligned, replacing the spark plugs, the plug wires and the EDIS coil pack I think I'm done working on the Mustang mechanically for the time being. In as much as it could have from the factory it runs like a scalded (small) dog when you floor it.
As of now it is a stable/reliable 3.8L v6 EDIS test platform that we can use for future FreeEMS EDIS testing. :-)
Tue Aug 21, 2012 2:02 am
New wheels for the Mustang :-)
File comment: Stock 2003 Ford Mustang GT wheel for my 1997 Mustang
Tue Aug 21, 2012 3:40 am
I sold this car last spring (2014).
Mon Mar 02, 2015 1:42 am
