Page 6 of 17
Re: 1989 Ford Courier - FE-DOHC Turbo conversion (DSL beware
Posted: Fri Jan 28, 2011 12:59 pm
by tpsretard
Should you ever have problems with your 4 ignitors.
the Bosch 0 227 100 211 is a 4 channel ignitor and seems very strong. can get it at a wrecking yard.
Subaru nissan audio and more use them.
Must say, i just red over this.
I love the project.
Posted: Fri Jan 28, 2011 7:43 pm
tpsretard wrote:Should you ever have problems with your 4 ignitors.
My family sparky told me that he has never seen a J701 or J121 die :-) mops from this forum ran high dwell on a 6 cyl in dizzy mode through one of them with insufficient heatsinking and didn't kill it. Mine are very relaxed driving one coil only.
Good to know. I *think* there is a thread on that somewhere, if I had more time I'd dig it up.
I love the project.
Thanks man! :-) It'll be cool when it's finished and totally stealth and has FOSS code and hw running in it.
Posted: Wed Feb 09, 2011 11:16 pm
Last night the last essential pieces of engine went on. Today is tidy up some wiring/attach a few hoses, brace the block to the chassis, and screw with my ms2 to make it run with a different trigger. However, today also marks a special moment, my Puma boards arrived! So, the ute should be running FreeEMS in a few days/weeks, and how good will that feel! Ute, built by me, software coded by me, hooray! Just need to ditch the LC1 and it'll be 100% diy and 100% open source. The only parts of that truck that aren't modified are the dash and guts of the dash, ie, not much! I learned to drive in it, too. It's a special truck for me. And it's about to get even more special! :-)
Posted: Sun Feb 13, 2011 2:16 am
Fired it up around 330am this morning and took it for a drive! The 1.8 runs sweetly and I do not miss the 200cc and the short stroke will be nice insurance :-)
Gotta sort out the ignition today, dodgy plugs, then confirm sweeeeeeeeeeeet running. Then write code :-o
Posted: Wed Mar 02, 2011 10:10 pm
I've updated the first post in this thread to reflect the new and much improved state of Engine Management on the vehicle! I'm proud to announce that this truck is now under FreeEMS control and is NEVER going back under MS control again, period. See the first post for a picture and short explanation.
Re: FreeEMS Powered '89 Ford Courier FE-DOHC Turbo (DSL bewa
Posted: Fri Mar 04, 2011 4:47 am
http://www.youtube.com/watch?v=Edy5-1YW8sc
This is just the beginning my friends :-)
Posted: Sun Mar 06, 2011 2:56 am
Goodbye engine number two... Another rod failure, too much boost/torque/power for the stock bits, again. Fail.
Posted: Sun Mar 06, 2011 3:49 am
by Spudmn
Fred wrote:Goodbye engine number two... Another rod failure, too much boost/torque/power for the stock bits, again. Fail.
Gutted.
Any damage to the block?
Posted: Sun Mar 06, 2011 5:40 am
Just the man I wanted to talk to! Got a land line? I'd like to have a chat! :-)
Damage to the block? Yes! Here is a fb pic for starters, more later:
Block is very well ventilated again...
Posted: Sun Mar 06, 2011 5:44 am
But, holy fcuk was it quick... :-)
Future plan is:
F8 crank
FE-DOHC 10:1 pistons
Custom HIGH quality rods and rod bolts
FE5A cams or custom hotter cams
The rest the same. With that combo I could reliably rev to 8500, make lots of power, torque and be happy. Past that I'd need a dry sump.
