Exported as a 929 without the rotary, turbo and other goodies (LSD, etc) to NZ, Australia, South Africe and Europe.
They were offered in 3 body shapes - coupe hardtop, 4door hardtop and sedan. Came with 1.8 and 2.0l 4cyl SOHC petrol engines, 2.2l 4cyl diesels, 13b injected rotaries, 12a carbys and 12a inj turbos. Some of the low spec models were equipeed with solid rear axles.
The sedan is almost a completely different body to the hardtops, with a very sedate and roomy interior. It was the sensible car, the hardtops where the crazy ones with all the gadgets.
Very advanced for a 1983 car, with:
- power windows
- central locking
- l.e.d dash (rather than the digital displays of some other 80's jappas)
- independant rear suspension, semi-trailing arms (suspension design is almost identical to fc3s Rx-7)
- 4 wheel discs (250mm vented fronts)
- digital fm radio/cassette player and boot mounted amplifier
- air con
- power steering
- osciallating air vents in dash
- electronic climate control system
- 8 way adjustable seats, very comfy!
- cd of 0.32!
- 15" alloys!
My example is powered by the original 12a (1200cc) 2 rotor wankel engine. With a single barrel nikki style throttle body and a non intercooled turbo setup rated at 165hp standard. It was the fastest car in japan briefly until overtaken by the r30 fj20det skyline.
"Using an Hitachi ( HT-18 ) turbo, the analog controlled EFI computer devilered it's mix via 2 "high flow" injectors mounted in the engines centreplate. The air mix would arrive via a staged throttle body & progressive metering measured via a TPS to the ECU. Combining the relatively small turbo with it's short intake manifolding ( intercoolers wern't common in the early 80's ) endowed the 12A with instant throttle response devoid of any lag. The trade off however was to be found in the engines top end power." Source
"It has a 3-throat throttle , as do all the Turbo engines , and it looks a lot like a carburetor. What this does is allow a single throttle to work as the primary throttle , which means that it opens first , then the two secondary throttles open at around 15% throttle. The benefit to doing this is that Mazda could get away with running only two injectors , located in the centre engine housing in the primary ports. At closed and up to 15% throttle, the primary ports are the only ones getting air-flow through them , which means a higher gas velocity , which in turn means better atomisation of the fuel" Source
The ecu is not quite quick enough to react to big changes in throttle position, so a mechanical vacuum/boost actuated switch of some description is used to open the injectors up if you give it a sudden hit on the throttle.
They run an electronic dizzy which retards under boost.
My car:
- Rare blue interior
- Lots of new parts from Mazda
- Tein FC3S fully adjustable coilovers
- Megasquirt & water injection (setting it up atm)
- FC3S brake upgrade (setting up atm)
- Full rewire
- 17" wheels, 255 Potenzas
etc
