viewtopic.php?f=3&t=1262
The Snot Rocket
Hello,
My name is Simeon, I have a 1979 Volvo 245 with a B21A engine.
That is, a 2100cc SOHC 4-cylinder gasoline engine, with a
carburettor and points ignition.
The motor makes about 100hp stock.
Ultimately, I intend to convert the motor to EFI and electronic
spark control, as well as adding a turbocharger.
I bought the car in February of 2010, and spent much of the year
getting it stable. The engine runs a whole lot better now, it
used to diesel and was hard to start hot. A tune-up, a few sea-foam
treatments and a couple of long road trips have made the car a
lot happier, though she is still dog-slow.
I've divided my goals up into phases, the first phase will be
getting a FreeEMS system up and running and controlling spark
only.
Second phase will be building a pressurized fuel system and
getting the car running on EFI reliably.
Third phase is adding turbocharging. I have manifolds and
turbochargers in my parts bin from several turbocharged Volvo
motors, including two B21FTs, a B230FT from a '89 740T, and a
turbo from a '94 850T (a TDH04-15G).
In the long term, I'm interested in implementing lean-burn maps
and techniques in order to reduce the fuel consumption of the
car, while retaining performance. I expect to experiment with
water/meth injection as well as EGR. I want to fully instrument
the engine with WBO2 and EGT/cylinder.
I'm a competent shadetree mechanic, good with a soldering iron.
I'm smart, but I doubt I'll be designing boards for FreeEMS. I
really want to get into the software, I know I need a running
car to really make a difference here though.
I became interested in FreeEMS after spec'ing a MS3 and then
realizing I would be unable to use the EMS to control an e-fan
using PWM. If the source was free, it would be trivial to
experiment with fan duty cycle. As they closed the source, it is
now impossible. I have no bad feelings, they have the right to
choose their license, however, the license they chose does not,
and will never work for me. The FreeEMS license[s] do work for
me, in perpetuity, and, with luck, I'll be able to contribute
back to the project. Making thirty-something-year-old cars
awesome is a good thing to get into.
This FreeEFI thing is pretty awesome, and I'm happy to be a part
of it.
To summarize,
My goals are to roughly double my power, on a stock bottom end
(Volvo redblock motors are good for way more) and, ultimately,
double my fuel economy. Resulting in a fun and economical
roadtrip machine (Canada is a large country).
My wagon, on a forest road outside of Thunder Bay, Ontario.
(She is a roadtrip machine, so far, ~10,000km of tripping under her [timing] belt)
