After a good result of a Mega Squirt project on a '90 Mazda pickup with a F2T engine I decided to add a fuel injection project to the beast.I purchased a tuned port manifold base for the Vortec heads(also done while Fred was on his epic 1st US tour) & cut the runner tubes off the the cast base plates,added 1.75 mandrel bent 90 degree tubes to those, and machined up base plates for throttle bodies.
Then I made 4 2 barrel ITB's
Also fabbed linkage to balance pairs to each other and side to side.Also machined up air cleaner bases, and tops.
Also note that for ign. I used LS1 coils for a CNP settup.To supply fuel I fabbed up a surge tank that hangs below the stock tank at a slight angle to feed any air back to the main tank .
I may need to add a second low pressure pump to insure constant fuel supply until the main is empty, but so far this seems to work well.
Now to operate this pile of billet & cast I built a MS3 with all the bells & DIYauto tune harnesses . Currently is running and partly tuned (well enough to drive but not as good as it can do).Am setup on wasted spark,batch injected as I don't have the CAS sorted out yet.I've got a Ford VR cam sensor mounted on a Chevy disty. base,with a 50/50 lobe on the shaft.No pics of this yet.
I've been following FreeEMS while this work has progressed, and got really excited when the PUMA 1 was brought out so I got Fred to hook me up
I've been a bit busy soldering up harnesses so I've not found BOM's for the Puma yet but am going to start pushing on that.
Thanks for looking,thoughts & comments welcome.
Gimpy
 ) VR sender ,I tested while it was still carbed ,with a EDIS 8 & no control it ran @ a solid 10 degrees advance.
 ) VR sender ,I tested while it was still carbed ,with a EDIS 8 & no control it ran @ a solid 10 degrees advance. I want to build an epic EFI electronic ignition beetle engine one day, and it'd be more than happy to have your work on it, even if I have to pay for it
