Maybe in 5 or 10 years, if you still have it ;-)ToxicGumbo wrote:Well, probably with plenty of arcing and rough engine behavior, but that's the spice of life.
Get well soon!I spent most of today feeling pretty ill and didn't make much progress.
Hooray, a technique that I've used for a long time and often recommend :-)I'm motivated though and really want to get this done, so in an attempt to hold myself accountable and be more visible, this thread will start to see more activity.
Pics or it didn't happen. Don't be shy. Hacked means hacked, we all know it'll be a bit ugly, so out with it! :-)The Toyota ECU's been hacked up so that the stock PCB sits firm in the case with elbow room for the Jaguar.
Short answer: whatever fits. Longer answer: 0.1mm^2 would be enough for 1 amp of current that an injector draws. The issue is that over distance, you'll drop voltage, but you've got no distance in the case. The other issue is vibration killing thin wires FAST.This brings up an issue though: wire gauge for injectors, coils, fuel pump, etc. I've seen a variety of wire used in peoples' projects and in some cases I think the choice was "just good enough" for proof-of-concept runs.
Ideally:
0.75mm^2+ for injector wires
almost anything for fp relay
almost anything for low current coil control signals
almost anything for all inputs
big as possible for grounds (plural, parallel = good)
smaller than grounds for power (but this only applies to the loom, really)
Consider glueing blocks to support it, and siliconing the board onto those carefully. My jag-in-oem setup has it flopping, which is clearly not reliable, supported by wires, and regulators only. Icky. Also consider: viewtopic.php?f=67&t=2221I'm also having issues reliably mounting the Jaguar into place, but that's not high priority at the moment.
