https://twitter.com/FredCookeNZ/status/ ... 6678509570
https://twitter.com/FredCookeNZ/status/ ... 7530044416
https://twitter.com/FredCookeNZ/status/ ... 2913512449
Interesting to see the different numbers at different temperatures and engine speeds.
- 88psi rev limiter coolant fully warm, but oil not fully warm
- 80psi hot auto shifts gears WOT highest I saw
- 75psi hot auto shifts gears WOT lowest I saw
- 60psi hot cruising 2500 RPM or so (guessed)
- 55psi hot cruising 1500 RPM or so (guessed)
- 55psi cold neutral idle
- 50psi hot neutral idle
- 47psi hot in gear idle
- 45psi hot overrun after rev limiter in neutral, RPM falling a little low before being caught
A lack of time and that crappy idiot light sensor/switch cost me some weeks of enjoyment and use! Damn thing!
I guess I do have something to order: A fresh switch from Volvo! :-)
