It's time to document the loom/pin out!
Standard wiring, except:
spr4 = second power
spr3 = RPM in, "second trigger" JS10 jumper location
spr2 = Spark B - connected to R29 pad, but drives D15 (D16 is driven by what usually drives D15, and vice versa)
spr1 = Spark A - connected to R26 pad, and drives D14 as normal
IAC1A = INJ4
IAC1B = INJ3
IAC2A = INJ2
IAC2B = INJ1
ign out = map in
Wire labeling:
purple, fuel pump = fp relay out
green with white stripe, white with green stripe, blue with white stripe, white with blue stripe, iac** = iac**/inj1,2,3,4
red, 12vdc = power inputs, 1 and 2 (std and spr4)
grey coax, IGN = RPM in main/second trigger, and CAS ground using shields, main goes to std in, tselect -> sg1, through opto v3 circuit to optoout, jumpered to tsel
green, F-IDLE = spr2/ ign 1or2
blue ,TPS-SIG = spr1/ ign 2or1
grey, TPS-VREF = 12v power out to CAS
pink, O2 = wideband 0-5v input
dark brown, "pin36" = ground out to P&H board
orange, IAT =  5v out to P&H board
yellow, coolant = ext map sensor input
unused db37:
fidle
inj1,2,3,4
from P&H box:
INJ1 = inj1
INJ2 = inj2
same colour as INJ1 with black blobs = inj3
same colour as INJ2 with black blobs = inj4
									Daniel Horton's Extreme B6T BFMR
Re: Daniel Horton's Extreme B6T BFMR
This vehicle is up and running, not a bad idle for 800cc injectors and 1600cc engine and no tune and so on.
Need to update the docs in the previous post slightly.
