The point of this exercise is not to make 600whp as the turbo is likely capable, but just to see how well it works. I am using MS2Extra for engine managemnet and using the boost controller to control the turbo. There are still a few bugs in that scheme that I am working on. I will be adding a wastegat as a pecautionary measure this weekend. With the controls the way they are now I can start making boost around 2000rpms in 2nd gear and at about 3000 rpms it goes up past 12 psi, where MS is currently tuned for. I will update here as I learn more. Heres some pics, enjoy:
THis is the pipe connecting the manifold to the turbine inlet. Im adding a wastegate soon.
This is the downpipe before I added the O2 bung
the mock-up pics
vanes closed
vanes open
a side-by-side comparison with the t3/t4 I had on before
and another reference pic
and heres some Ford info on the turbo/VGT solenoid:
