View unanswered posts | View active topics It is currently Tue Mar 26, 2019 5:37 pm
Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
Fred's 1994 Volvo 940 Wagon
Daily driving it this week, today I parked badly (half way in two spots, no markings, but...) and came back to find this: https://twitter.com/FredCookeNZ/status/ ... 0186285056
Fri Aug 25, 2017 12:29 pm
Cleaned the rare polaris wheels on this tonight while I had the hose and wheel cleaner out: https://twitter.com/FredCookeNZ/status/ ... 1954898945
After, before, after:
Fri Sep 29, 2017 8:01 am
Took this for a gentle spin last night to pick up my spare Suzuki keys from a friend. I actually enjoyed driving it in a cruisy comfy kinda way.
Lower + up torque + fix front doors + respray + wheel restoration = win?
It's certainly at the bottom of the mod list, however it also has a squirter block in it that I'd like to use for another car. Which would require swapping something into this first.
And the lawn got mowed/weed whacked next to it, so the whole left side needs a clean.
Thu Nov 02, 2017 10:00 pm
Minor upgrade today, leaking oil filler cap removed, cleaned up, and seal replaced with a nice new IPD Viton one:
https://twitter.com/FredCookeNZ/status/ ... 3081589760
https://twitter.com/FredCookeNZ/status/ ... 0667197440
No before shot of the leak mess, sorry.
Sun Nov 05, 2017 10:02 am
Did the big coolant flush job on this yesterday!
Started with some weak caustic soda solution.
Then rinse.
Then strong oxalic acid solution for an hour of driving.
Then rinse
Then washing soda.
Then rinse, and rinse again.
Then pulled it all apart.
Found that the tstat was BROKEN not absent! :-D
Cleaned up the housing and head and another tstat and installed that with a new seal.
Still apart now... but only insides of 3 hoses to clean and it can go back together.
Tweets/pics:
https://twitter.com/FredCookeNZ/status/ ... 5507475456
https://twitter.com/FredCookeNZ/status/ ... 8010031104
https://twitter.com/FredCookeNZ/status/ ... 8664687616
https://twitter.com/FredCookeNZ/status/ ... 1621761024
https://twitter.com/FredCookeNZ/status/ ... 0318071810
https://twitter.com/FredCookeNZ/status/ ... 0075652097
https://twitter.com/FredCookeNZ/status/ ... 6484911104
https://twitter.com/FredCookeNZ/status/ ... 4437731328
https://twitter.com/FredCookeNZ/status/ ... 1240354821
https://twitter.com/FredCookeNZ/status/ ... 4340400128
https://twitter.com/FredCookeNZ/status/ ... 0470653952
https://twitter.com/FredCookeNZ/status/ ... 6543639552
https://twitter.com/FredCookeNZ/status/ ... 8970763264
https://twitter.com/FredCookeNZ/status/ ... 6301309953
https://twitter.com/FredCookeNZ/status/ ... 5067581441
https://twitter.com/FredCookeNZ/status/ ... 3100686338
https://twitter.com/FredCookeNZ/status/ ... 9233118208
https://twitter.com/FredCookeNZ/status/ ... 0577732608
https://twitter.com/FredCookeNZ/status/ ... 9619380224
https://twitter.com/FredCookeNZ/status/ ... 1544786944
https://twitter.com/FredCookeNZ/status/ ... 9165850624
https://twitter.com/FredCookeNZ/status/ ... 7384870912
https://twitter.com/FredCookeNZ/status/ ... 7997941762
https://twitter.com/FredCookeNZ/status/ ... 5869953024
https://twitter.com/FredCookeNZ/status/ ... 4978223104
https://twitter.com/FredCookeNZ/status/ ... 2991960064
https://twitter.com/FredCookeNZ/status/ ... 6467793921
https://twitter.com/FredCookeNZ/status/ ... 4657393665
https://twitter.com/FredCookeNZ/status/ ... 1050945537
https://twitter.com/FredCookeNZ/status/ ... 0702149632
TODOs:
Brake and/or tail light bulbs left side
Pick up and install left corner market light
Clean flame trap and oil/air separator (seal leaks, idle high because hose off to lessen leak)
Replace power steering pump and flush out lines (whining under load and at high RPM, heavy load on engine, not happy)
Lowering springs... OK, this isn't needed, but it would complement the look of the Polaris wheels... :-) Even my WOF man was asking me about them "are they factory" and saying how much he likes the look.
Sat Nov 25, 2017 9:59 pm
Cleaned the hoses and chucked it back together, doesn't over-cool now, however I think the 87 tstat is too low for the fan settings as the movement on the gauge is wider than I'd hope for from motorway cruising (lowest, about 1/4-1/3 from end to end) and idle fan on point (about half way).
Relevant tweets from today:
https://twitter.com/FredCookeNZ/status/ ... 5567607808
https://twitter.com/FredCookeNZ/status/ ... 4039863296
https://twitter.com/FredCookeNZ/status/ ... 5991436288
https://twitter.com/FredCookeNZ/status/ ... 2105569280
https://twitter.com/FredCookeNZ/status/ ... 6402679808
Reduced the idle back to a sane-ish 1k no load, 750ish in drive/reverse. Will be ultra low cold now, so next fix will be the idle valve that clearly isn't happy.
See previous post for more stuff to do...
Sun Nov 26, 2017 9:27 am
I took this thing for a very quiet sedate lap around the block to do a chore on another car, and bugger me, just up to 30kph up the road when splutter die. She died. Parked where I don't really want to for the night, will have to diagnose which of the common faults this failure is. Sigh.
Tue Dec 19, 2017 11:04 am
Guessed that this was the crank VR sensor, took one down to the car a few days later, wiggled the wires, and it fired right up (didn't try before the wiggles, so....). Tried to kill it with more wiggles and failed. Hmmmm.
Yesterday arvo, tried to start it, splutter splutter, crank crank, nothing much. Hmmmm. Tried wiggling the wire again, burst into life. Tried wiggling it a final time, killed it. Yay. Know what it was. So changed it out for a spare and it starts sweetly and is fine.
Tweet tweet, pic pic:
https://twitter.com/FredCookeNZ/status/ ... 3062506496
Also filled the 70 litre tank up with fuel last night, pushing the limits of engineering once again:
https://twitter.com/FredCookeNZ/status/ ... 4960391168
Gave it a good thrash this morning and am looking forward to better economy on this tank!
Also planning to tow the caravan with it in a few weeks, should be a laugh :-)
Mon Jan 15, 2018 4:22 am
Finally got around to sorting out the right rear flat tyre. Got a couple of photos of the inside of it... https://twitter.com/FredCookeNZ/status/ ... 6096976898
Image Image
No idea why it rubbed like that in one spot only. Quite odd. Didn't drive far on it like that, if at all, and if I had, the whole inside would be rubbed up and scuffed. Weird.
Replacement: https://twitter.com/FredCookeNZ/status/ ... 7635459072
Image Image
Wed May 16, 2018 8:32 am
Oil changed/upgraded: viewtopic.php?f=15&t=2693&p=44381#p44381
Also gave it a new magnetic drain plug and, of course, a fresh filter :-)
Washed down the block beforehand and had a look after a test drive, we have a head gasket oil leak:
https://twitter.com/FredCookeNZ/status/ ... 9886746624
Photos are near identical, but subtly different, so you get two, sorry.
Fingers crossed it lasts until I can 3.0 whiteblock swap it and take the squirter block for another vehicle...
Sun May 20, 2018 7:39 am
