1995 Mazda eunos (miata/mx5)
mikehudsonuk
Post by mikehudsonuk »
I'm posting this under duress
My car is a bog standard, tip top condition 1.8 1995 mx5. well it's a special edition so it has a nice wooden steering wheel etc but mechanically its standard. No LSD I've just worked out as well, cack (it was an option on this model).
Only mod to date is a very light lowering on original shocks
I will be adding FI (supercharger) soonish but will be getting a jaguar board in while it's still N/A so I can get it tuned while everything else on the car is stock. The board is going into a donor (functioning, I'm told!) ecu I got off ebay for £20 delivered.
I am pretty clueless with electronics so you may be about to read about someone releasing mysterious blue smoke..
Photo to come, comments welcome. I just learnt I need noninverting output ignitor drivers and a 250kPa MAP Sensor, so there you go, so do you if you've got the same car.
And I'm not interested in turbo charging just yet, thanks all the same!
Re: 1995 Mazda eunos (miata/mx5)
mikehudsonuk wrote:I'm posting this under duress
ROFL! That would be me, yes. Bumped the size from 50 to 150 so it was readable. BTW, you can go smaller. I do that sometimes :-)
Gutted! Boost will motivate you to add this very quickly.
Good plan ;-) I decided to justify that advice, and just wrote this: viewtopic.php?f=15&t=2293
Plug it in and try it before you strip it. You could also order a connector to use instead of pulling the used one out of the old board. Doing that is a PAIN and you get a spare ECU out of not doing it, if it does work.
Jaguar is pretty tough once assembled correctly! We welcome testing :-)
Not necessarily (for the MAP sensor), depends in equipment and goals. Non inverting is because of these reasons:
  • Polarity not software selectable (intentional design choice, not limitation)
  • CPU outputs 5V high during dwell
  • Normal (darlington) ignitors (such as yours) require a base current applied by exceeding the BE Voltage through a current limit resistor to dwell.
  • Non-inverting means 5V in == 12V out.
There you go, now you understand why :-)
Spoil sport. You've already told me that N-1 times, where N is how many times I told you it was a good idea.
Looking forward to pics. Especially if you're in some :-)
