View unanswered posts | View active topics It is currently Wed Oct 21, 2020 12:02 pm
This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
Trade, Pc oscilloscope + AVR128 dev board + PIC [EXPIRED]
Wideband Wizard
EDIT: Was "Looking for Trade, Pc oscilloscope + AVR128 dev board + PIC"
I have an extra POscope that I do not use, it is a usb based scope the sample rate is 200khz. Should be ok for automotive stuff.
http://po.labs.googlepages.com/
It also has:
-a signal generator, works but is limited,
-a spectrum analyzer, works
-logic analyzer, tried to use it but got no where.
Documentation is not very good, the device seems to have issue with some motherboard chipsets. The unit is almost brand new, I used it once to make sure it works. It does not come with probes , I just use a BNC to aligator clip setup since the bandwidth of the scope is so low.
I also have a new AVR128 devboard + module, http://www.futurlec.com/ET-AVR_Stamp_Board.shtml,
http://www.futurlec.com/ET-AVR_Stamp.shtml.
They have both been never used or only used once. It is a very good AVR dev board, I cut my teeth on AVR using the same board. Combine them with a cheap AVR JTAG clone and you have a very nice AVR development setup.
Also I have a USB pic programmer and maybe 30 various PICs. The PICs are from about 3-4 years ago. I do not remember much about the programmer. It will come with software to program the pics. I am willing to give away the PIC stuff to someone who wants to get started in embedded systems. I can not make any guarantees that the PIC programmer is 100% working, last time I used it was 3-4 years ago.
I am looking for the following:
-lab style power supply
-high end multimeter
-MS2 board
-Tech ART dev board for freeEMS
-anything electronics development related.
www.14Point7.com
Thu Jun 12, 2008 11:12 pm
