View unanswered posts | View active topics It is currently Mon Apr 12, 2021 1:24 pm
Reply to topic  [ 8 posts ]
Frankenso for rusEfi: kits or assembled
bare PCB for rusEfi to be used with an old 64 Mazda ECU case. These four layer boards are larger then the two layer Frankenstein boards, with these one has an option to solder an stm32f4 chip right on the board.
$39
http://forum.diyefi.org/viewtopic.php?t=2070 http://www.rusefi.com
Tue Dec 30, 2014 3:45 pm
Also available as a kit with the connector and all the I/O chips
$90
x1 Frankenso board
x12 low-side VNS14NV04
x3 op-amp LMV324IDT
x3 high-side TC4427
x2 2x25 header
x2 SD card socket
x1 VR INTERFACE MAX9926
x1 CAN interface SN65HVD230
x2 33uH Inductor
x2 CAP TANT 220UF
x1 IC REG BUCK 5V 3A
x1 CAP ALUM 680UF
x4 misc diodes for power supply
x1 HIP9011 knock detection chip
x1 4MHz osc for HIP9011
Tue Dec 30, 2014 3:47 pm
Have two fully assembled boards
https://www.tindie.com/products/russian/frankenso-01-assembled/
https://www.tindie.com/products/russian/frankenso-01-full-bundle/
Sun Jan 25, 2015 1:52 am
Interesting... is that the same ECU connector as 90's Mitsubishi/Toyota? Denso OEM ECU case?
Sun Jan 25, 2015 4:44 am
Yes, same 64 pin connector as 90's Mitsubishi/Toyota/Honda/Mazda. Yep, Denso OEM case from a Mazda 323/Protege/Miata.
Sun Jan 25, 2015 4:47 am
Second batch of assembled version 0.4 has arrived. Note larger proto area and two extra low current drivers.
Tue Nov 17, 2015 1:54 am
New batch of same exact Frankenso 0.4 has arrived - boards are back in stock.
https://www.tindie.com/products/russian ... ll-bundle/
Sat Feb 25, 2017 4:40 am
first batch of Frankenso version 0.5!
Prices are a bit up & new links:
https://www.tindie.com/products/russian ... led-board/
https://www.youtube.com/watch?v=MIPTD7_bjSA
Mon Jan 15, 2018 10:34 pm
