View unanswered posts | View active topics It is currently Fri Sep 25, 2020 1:25 am
Reply to topic  [ 2 posts ]
FS: assembled jag 0.7 alpha unit
I have for sale an assembled jag .7 alpha unit with case and extra wiring
I'm looking for 300 + shipping USD
its setup for gm iat and denso clt currently.
It also has no map sensor on it. I also recommend mounting the map sensor on the manifold or in the engine bay above the point where it goes to.
only thing it needs done to it is the cap mod to change to the correct size
I already have loaded different firmwares in it at times to check stuff, no issues loading firmware, baro was working when checked.
Pics up soon enough
I am here and irc #freeems channel all the time
Fri Dec 26, 2014 3:12 am
Hey man, I heard that you didn't know how to switch decoders in your custom build. That's really easy to do. What are the other things you need setup for an initial speed density setup? I can help you configure it and build the firmware for you to just use, if you want. Let me know. :-)
Otherwise, #freeems-ot is the IRC channel you're often in (when your internet is working). You can get on it here:
http://webchat.freenode.net/?channels=% ... aguarBuyer < edit the URL to change the nick to suit.
Fri Dec 26, 2014 10:06 am
