View unanswered posts | View active topics It is currently Mon Sep 21, 2020 12:56 am
Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Jaguar 0.7-alpha kits For Sale
EXCELLENT!!!!!
Tue Jul 01, 2014 6:06 am
Does that mean that I have to wait another month for my #1's because of walinksy's (unasked for) combined shipment?
Tue Jul 01, 2014 1:07 pm
Sorry Matthijs; hadn't realized that. Just thought combining shipment would be wise. I'll contact Andy; and have mine shipped seperatly.
Tue Jul 01, 2014 4:58 pm
It's not recommended to wait for number ones. It can cause a bladder infection.
Tue Jul 01, 2014 8:04 pm
Hello there,
I am interested on the following:
a) 1 option #2
b) 1 USBDM.
c) 1 Case
d) 1 PM Re Development Boards
I am trying to use it on a BMW 318i 1984 European Version, it is an M10 engine currently running on its stock L-Jetronic. Please let me know if you think the Jaguar is not a good fit for what I am trying to do.
If you're an admin and can see my e-mail address, please feel free to shoot me an e-mail.
Remove disallowed content.
Wed Jul 09, 2014 4:17 am
I have PMed wilbertcr with the hardware cost and asked for the shipping destination.
wilbertcr:
For your BMW M10 application since I'm not familiar with the engine, I have a few questions:
    1. What type of crankshaft position sensor do you have (ie: VR sensor or Hall Effect sensor)?
    2. What is the crankshaft position sensor pattern (ie: 1 pulse per cylinder, 36 teeth minus 1 tooth, 60 teeth minus 2 teeth, etc...)?
    3. Does your engine have a camshaft position sensor?
    4. What kind of ignition system are you using now (ie: wasted spark ignition, coil on plug, distributor)?
    5. Which kind of ignition system do you plan on using in the future?
    6. Are your fuel injectors low impedance (approximately 1 ohm if measured with a DMM) or high impedance (9-20 ohms if measured with a DMM)?
    7. How many fuel injectors do you have on the engine?
    8. Have you added a turbocharger or supercharger, or do you plan on adding one? (I have optional MAP sensors, the standard MAP sensor is good to 250kPa, which is about 10-12 PSI of boost) For the MAP sensors, I can supply a 115kPa sensor for non-boosted engines, a 250kPa sensor for moderately boosted engines or a 400kPa sensor for wildly boosted engines. The 400kPa sensor requires an adapter board which is an additional $5.00 USD.
The reason for the questions is to make sure that the FreeEMS firmware is a good fit for your engine configuration.
Please read this thread to get an idea of the current capabilities of the FreeEMS firmware: viewtopic.php?f=54&t=1084
Also be sure to start a thread in the Users Rides section for your car so that we can learn more about your project and give advice on how to proceed:
http://forum.diyefi.org/viewforum.php?f=3
Wed Jul 09, 2014 1:34 pm
The second post (http://forum.diyefi.org/viewtopic.php?p=38400#p38400) has been updated with the kits I have shipped as of Wednesday July 9,2014.
Wed Jul 09, 2014 7:31 pm
<snip>
wilbertcr, please answer these in your new thread rather than here. Thanks :-)
YAY, re shipped list! :-) https://www.youtube.com/watch?v=JCmkZFMSuFQ
Wed Jul 09, 2014 7:42 pm
The second post (http://forum.diyefi.org/viewtopic.php?p=38400#p38400) has been updated with the kits I have shipped as of Thursday July 10, 2014.
Thu Jul 10, 2014 8:27 pm
Fred wrote:
<snip>
As requested by Fred, here's the follow up to Andy''s questions:
viewtopic.php?f=3&t=2477
Fri Jul 11, 2014 10:50 pm
