View unanswered posts | View active topics It is currently Fri Dec 04, 2020 11:52 am
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
2 Jaguars 0.6-alpha [SOLD!]
If your pads lifted off, you got it way way too hot. You should not rely on traces to keep pads in place... the pad is bonded to the glass substrate unless you get it so hot that you destroy that bond. This tends to only happen to me when desoldering things, and then only sometimes; usually when it's not the first desolder for that PCB location.
Thu Apr 24, 2014 10:01 pm
Agreed, thank you Fred. As I am perfecting a SMD technique, am finding you walk a fine line between keeping it hot enough to do it quick and not hot enough to do it quick. Also I think my iron lies a little about the tip temperature. That aside I can attest to the fact that this board has 110 out of 112 good looking joints. Of course always buyer beware when deeling with some guy who built the thing in his basement :) I haven't testing these things + my soldering under severe vibrational loads. Who of us can?
Thu Apr 24, 2014 11:23 pm
LOL, fair enough. FWIW, I run my iron well hot enough to ruin the board, but keep the joints quick. I lower it if I'm flood soldering such as CPU or FTDI.
Thu Apr 24, 2014 11:32 pm
little den of jaguar cubs
Fri Apr 25, 2014 12:58 am
just so there is full disclosure
here is the good board I just finished for nonamebrand:
Here is the "blemished" board I used for practice, but still should work and is only $17:
Sat Apr 26, 2014 3:40 am
Tack it in 1 or 2 or 3 places before you get busy. I guess you did that for nonamebrand. Then if you don't line it up perfectly the first time, you can soften and slide until it is, then once it is, tack more and more until stable, then flood. In any case, 17 is an absolute bargain for a working CPU on a Jaguar board! :-)
Sat Apr 26, 2014 11:44 am
I can get it for this 17$ for playing with it. How much could cost shipping cost to spain?
Sierra XR4i 2.0T
Sat Apr 26, 2014 12:57 pm
yikes, shipping from my post office that's about $25 also--small flat rate box. Is there a better method of international shipment?
Sun Apr 27, 2014 9:19 pm
I think the (size of) box is the killer. Would a bubble envelope do the trick?
$25 for sending + $17 is a bit steep for me. Otherwise I would take it in a heartbeat (say like $5 shipping or so)
Mon Apr 28, 2014 1:45 pm
Okay yes that looks much cheaper. I didn't know the envelopes can be up to 20mm thick--so I could probably stack something rigid in there--to make it reasonably safe. That's about $6.
Mon Apr 28, 2014 3:42 pm
