I have two (2) remaining Jaguar A3 boards left, I can supply you with the following configuration for $82 USD each plus shipping from Indiana, USA:
Jaguar A3 PCB,
MCU with the Serial Monitor loaded,
MAX9926,
FTDI USB UART,
up to six (6) Injector drivers
both the Fuel Pump/Fan drivers.
This will be a functional MCU/all silicon components board with the capabilities of a TA board, including already having the Serial Monitor program loaded so you can use the Load/Run jumper. You will need to supply the passive components as found in my BOM at https://github.com/DeuceEFI/Jaguar/blob ... Jaguar.ods in order to use the board (you will need to supply the remainder of the components yourself).
Complete Jaguar FreeEMS forum section: viewforum.php?f=67
Supported Injection methods: viewtopic.php?f=67&t=1543
Supported Ignition systems: viewtopic.php?f=67&t=1541
Instructions on how to build the Jaguar A3 PCB: https://github.com/DeuceEFI/Jaguar-Assembly-Manual
And finally a link to videos of the Jaguar A3 board in action on a GM 3.1L V6: viewtopic.php?f=67&t=1627
[Edit 10-13-2012] Both Jaguar A3 boards have been sold and shipped, congratulations malcom2073 and ToxicGumbo!
FOR SALE: Jaguar A3 boards for FreeEMS [ALL SOLD! OBSOLETE!]
- ToxicGumbo
Re: FOR SALE: Jaguar A3 boards for FreeEMS
For reference, I've just contacted DeuceEFI for a board.
-Jeff
-Jeff
So far masterkorp and ToxicGumbo have expressed interest in purchasing the 2 Jaguar A3 boards.
If either of them decides not to take it, I'll take one.
